Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 46
Thread: HID Motorbike Conversion Kit
  1. #21
    Mabels Old Man's Avatar
    May 2006
    The Dark Side
    Re: HID Motorbike Conversion Kit
    Quote Originally Posted by jarl View Post
    However, in reality they're dangerous, cause more glare to other road users and prevent you from seeing so well.
    You can reduce the glare by adjusting the headlight, however I don't care what the report says they're a hell of a lot better to ride behind then some headlights.
    Quote Originally Posted by Daz Max View Post
    As above
    HID lights are illegal on motorbikes and will fail an MOT.
    They are legal on cars that have self levelling suspension (which bikes don't!) and must be able to be independantly switched off.
    I know quite a few people who've passed MOT's with HID's in with no problem.
    The article might carry more weight if it was British and not North American cos Merkin laws are different
    1995 Fireblade Urban Tiger
    2009 BMW R1200GSA
    Events Manager GS Club
    AlanH's Avatar
    Bristol, UK
    Quote Originally Posted by Mabels Old Man View Post
    They may be better to ride behind, but try when they are coming towards you.
    UK Department of Transport British enough for you???
    Aftermarket HID (Xenon) headlamps
  4. #23
    Lutin's Avatar
    Galway
    That's the one I found when looking into this a while ago. Still, some folks are getting their bikes through the MOT okay.
    You pays your money.........
  5. #24
    AlanH's Avatar
    Bristol, UK
    That's because some MoT Testers are not thorough enough. That reflects badly on the MoT tester rather than being any positive endorsement for an illegal light setup.
  6. #25
    May 2006
    The Dark Side
    Yep that's much better.
    I still maintain that if the headlight is properly adjusted they shouldn't cause undue dazzle.
    2009 BMW R1200GSA
  7. #26
    Lutin's Avatar
    Galway
    You are supposing that all the bikes fitted with HID kits have not been tested correctly.
    That's some statement.
  8. #27
    AlanH's Avatar
    Bristol, UK
    Read the article from the UK Department of Transport.
    A retrofit HID kit is illegal for road use. Should MoT testers pass illegal lights or not? What we need is a definitive answer from an MoT tester as to what the book says.
  9. #28
    May 2006
    The Dark Side
    That could be used to bolster my arguement that if they're adjusted properly they don't cause a problem.
    2009 BMW R1200GSA
  10. #29
    AlanH's Avatar
    Bristol, UK
    The problem is, as explained in the other article posted by Jarl, to get the cutoff correct, you need to replace the reflector and the lens. If you do that then it will be properly adjusted. If you don't do that, the only way you can reduce the glare being experienced by other drivers is to aim the light low. You'll then get less lighting in the distance than if you just had a conventional bulb.
    Don't forget that on a left-hander, the beam is tipped up into the eyes of an oncoming motorist and, as there is no sharp cutoff with HID when it's installed with an incorrect lens and reflector, that can be very dazzling when compared with a standard bulb regardless of how the beam looks when pointed at a wall with the bike upright.
  11. #30
    May 2006
    The Dark Side
    Not arguing against that but I've pointed mine at the garage door and it has a very defined cut off.
    2009 BMW R1200GSA
  1. Thinking of a non-motorbike GPS?
    By Dee Duble Yuh in forum Mechanical Advice
    Last Post: 09-07-09, 11:18 AM
  2. Fat man motorbike jackets?
    By ROCKOZ in forum Recommended Dealers / Service Providers / Campsites
    Last Post: 20-03-09, 03:42 PM
  3. Uses for a motorbike Helmet..
    By GeoBloke in forum Chatter
    Last Post: 18-01-07, 08:46 PM
  4. RS Motorbike Paint
    By paultheold in forum Recommended Dealers / Service Providers / Campsites
    Last Post: 17-12-03, 07:13 PM
