Re: HID Motorbike Conversion Kit
I suppose you could look at it another way...
A HID light source is around 3 times stronger than a halogen light source. If you are putting it in a light housing designed for a halogen bulb, the peripheral light that hits an oncoming motorist will be at least 3 times greater (ignoring the cutoff and scatter issues).
Do you think an oncoming motorist may find your light to be too bright if you had a 180/165 watt bulb fitted? The effect will be much the same.
