Results 1 to 3 of 3
Thread: Rear wheel spacers
    Titch's Avatar
    Titch is offline Senior Member
    Feb 2009
    Oldham, Manchester
    Rear wheel spacers
    I'm in the process of changing my wheels on my 600TA from the standard wheels to Dominator wheels, and also changing the rear from a drum brake to a disk brake.
    My question is... does anyone know where I can get hold of a right hand side (disk side) wheel spacer for the rear wheel....?
    I have everything else, but this is now the only part I'm missing.
    Anyone got one spare lying around... or know where I can get hold of one...?
    Oct 2008
    Belfast
    Re: Rear wheel spacers
    Hi mate
    Some times with conversions the original spacers wont be the right size, your best bet is to get one made to the right size needed. Get yourself a handful of m18 washers and tape some together to test fit with, unless you know the size you need it's an easy way to find out.
    How you getting on with the conversion, everything going ok I hope.
    CM
    Titch's Avatar
    Feb 2009
    Oldham, Manchester
    Cheers mate, was just lookin at yours the other day.... looks mint...
    Was all set for gettin the rear 1kcc vara wheel, n a vara 125 front, but then found a mint set of Dominator wheels (plus funds went elsewhere, so ran a bit short), and get the pair for just over £75 +p&p. The Varas were going to set me back around £150-200 inc. tyres disks etc, plus the messin about finding the right size disks, so the Domi wheels seemed the easier & cheaper option...
    So I now have a rear swing arm from a '93, complete with a caliper bracket and caliper... A master cylinder inc pedal linkage, fluid reservoir, and hoses from a AT, and a set of Domi wheels on route.
    Lookin at the specs/diagrams, the wheels for a disk rear have a spacer on both sides, whereas the drum only has one on the sprocket side, hence why I need one for the disk side.
    Will get some pics on when swap over complete.
  1. Wanted: Dominator rear wheel spacers
    By catteeclan in forum For Sale / Wanted
    Last Post: 05-11-09, 04:07 PM
  2. Wanted: Rear wheel
    By choobidoobi in forum For Sale / Wanted
    Last Post: 15-05-09, 12:58 AM
  3. Wanted: RD04 rear axle spacers
    By Jeff@TheQuadShop in forum For Sale / Wanted
    Last Post: 01-11-08, 01:44 PM
  4. Rear wheel out for new rim.......
    Last Post: 24-09-08, 10:43 PM
  5. Replies: 2
    Last Post: 02-06-08, 11:08 PM
