Results 1 to 10 of 11
Thread: Crashbars OK but a bent gear lever
    vdv2020's Avatar
    vdv2020 is offline Junior Member
    Aug 2009
    Luxembourg
    Hi,
    I have SW Motech crashbars and I have put my bike on it's left side very slow-mo at basically a standstill. The crashbars saved everything, but the gear lever is now nicely bent towards the engine
    I will get it straight and now I consider a foldable lever (from Touratech), but I am not sure if it will help in case of such falls. Any other suggestions?
    jarl's Avatar
    jarl is offline Senior Member
    Apr 2009
    Bath
    Re: Crashbars OK but a bent gear lever
    Save a few pennies and get a cr85 lever:
    cr85 gear, Trials Motocross Bike Parts, CR, Used items at low prices on eBay.co.uk
    They fit fine. I got an aluminium one because it'll bend before the gear selector shaft does. I can assure you they work
    vdv2020's Avatar
    Aug 2009
    Luxembourg
    er, what does it mean "BREAKING" ?
    you suggest this one?
    HONDA CR 80 CR 85 GEAR SHIFT LEVER BREAKING CR85 CR80
    AlanH's Avatar
    Bristol, UK
    Breaking - breaking for spares. It's a used one. I'd get a new one for the same money.
    Try The UK's biggest choice of motorcycle parts for Japanese and European machines. as they stock decent aftermarket alloy gear levers.
    vdv2020's Avatar
    Aug 2009
    Luxembourg
    Darn, I did not know the phrase "breaking for spares". And I did not think of salvaging in this context.
    AlanH's Avatar
    Bristol, UK
    No probs. Your English is better than my French, German or Luxembourgish
    Grendel's Avatar
    Southampton, Hampshire
    African Twin gear leavers also fit.
    And may be cheaper 2nd hand?
    My TA 600 Page:
    Southampton Safe house
    Sep 2008
    mainland
    Hi, I've just bought and installed one from Touratech.
    Just like you i (slowly) dropped my 700 because I had forgotten to set out the side stand.
    My crash bars did their job ,aldo the gear pedal was slightly bent.
    Not that bad only each time the gear shaft also receives a kick and the foldable gear pedal should prevend that in the future.
    Now i'am looking for a foldable break pedal (in case i drop the bike on the other side) ,TT has them for BMW's ,so far not for Honda's.
    Enjoy
    vdv2020's Avatar
    Aug 2009
    Luxembourg
    @GreyAlp
    Yeah, it's a pity about foldable brake lever not being available for Honda.
    As for the gear lever from Touratech - does the rubber from original fit on this one?
    Sep 2008
    mainland
    Well i only did about a 100km with the foldable gear lever and no problems with either winter boots or riding shoes.
    And yes you could remove the original rubber and fit it on the foldable gear lever ,its the same diameter.
    Only the stick on the latter is shorter so you should cut off 1 cm of the rubber.
    Thats what i"m going to do because the bolt and nut that holds the spring is (sometimes) the first thing your boot is touching when shiffting gears. With the rubber also on the stick it should make it ,not entirely but at least a bit more even.
    Enjoy
  1. 650 gear lever mod...
    By Dickster in forum Transalp
    Last Post: 21-06-09, 03:21 PM
  2. Gear lever
    By joe 90 in forum XR
    Last Post: 05-01-09, 10:47 AM
  3. Bent rear brake lever
    By DaveS in forum BMW
    Last Post: 28-05-08, 07:21 PM
  4. Gear Lever - new one ?
    By Keef in forum Dominator / FMX
    Last Post: 05-07-07, 07:18 PM
  5. Bent gear change shaft
    By Tricky in forum Chatter
    Last Post: 18-05-06, 10:03 AM
