Results 1 to 9 of 9
Thread: Exhaust paint
    fat-mal's Avatar
    fat-mal is offline Senior Member
    Mar 2008
    caerphilly wales uk
    Exhaust paint
    Can any of you good people recommend a heat resistant matt black to paint/spray the exhaust on my 700 TA. I have used Plasi coat High temp spray coat but it rubs off. Cheers fat-mal
    '08 XL700v
    ."Don't take life too seriously;nobody gets out of it alive."
    -- Elbert Hubbard
    Re: Exhaust paint
    Do hammerite make a heat resistant paint?
    mad4it028 is offline Senior Member
    Aug 2009
    peterborough
    Re: Exhaust paint
    barbique paint from b&q
    largewayround's Avatar
    May 2008
    Aberdeen, Bonny Scotland
    Re: Exhaust paint
    I got some BBQ spray paint from Halfords.. last year .. did the job fine.
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    Re: Exhaust paint
    I have tried a few over the years, ultimately they all need need re applying occasionally. I generally use something like Sperex VHT in an aerosol, brushed on stove paints look, errm, brushed on!
    High temp paints are porus to let the heat out. Unfortunately this means that they let moisture in......
    '02 Transalp
    '01 Transalp (Transrat)
    '98 Transalp
    '91 NC30
    '08 Hornet (Vanessa's)
    Zenarchy's Avatar
    North East UK
    Re: Exhaust paint
    I used some barbecue spray paint from B&Q on my old end can. I think it was plasti-kote brand so not sure if that's different to what you've already tried but it worked OK for me and didn't rub off or peel.
    I think you needed to get the exhaust up to a certain temperature within a certain time after applying it from what I remember or it doesn't cure properly. I warmed the exhaust up (though not too hot) between coats too (and kept the coats light) after reading a tip on a forum somewhere. Maybe that helped.
    The Africa Twin end can is mild steel though so if it's to paint stainless then maybe it wouldn't work.
    That's the problem I had eventually. Looked great at first, but over the course of a year, it'd obviously started rusting again underneath the paint.
    Eventually I had to replace it with a stainless can, but it did a surprisingly good job of making the old one look reasonable in the mean time considering how bad it was before I started.
    oggy's Avatar
    oggy is offline Senior Member
    Aberdeenshire
    Re: Exhaust paint
    Plastikote wood burning stove paint spray can worked for me. Key the old paint - first removing any corrosion - immerse can in hot water for 5 minutes to avoid runs and a more even application of paint. Shake very well, apply 2 or 3 thin coats with suitable drying time in-between and rub down each coat lightly with wet/dry. Good matt/satin finish to match rest of bike. Original paint is poor and very liable to flaking off.
    Exhaust fairly simple to remove on 700
    fat-mal's Avatar
    Mar 2008
    caerphilly wales uk
    Re: Exhaust paint
    Thanks for your help. fat-mal
    '08 XL700v
    -- Elbert Hubbard
    funny is offline Member
    Feb 2008
    dorset
    Re: Exhaust paint
    Hi, have you tried"graingers pot black " ?.It is painted on but smooths out really well with no brush marks visible,I have used this product on exhaust down pipes and silencer fitted to a transalp .
    Sperex is a brilliant product but more suited to auto applications.
    I have tried other products but keep going back to Pot Black.
    Hope this helps
    Mike
  1. Paint
    By Crackerjacker in forum Mechanical Advice
    Last Post: 03-11-09, 01:49 PM
  2. Paint for exhaust pipie
    By RickSkye in forum Mechanical Advice
    Last Post: 08-04-07, 09:33 AM
  3. Exhaust paint
    By Watchman in forum Dominator / FMX
    Last Post: 20-02-07, 03:27 PM
  4. Paint -- Paint Code -- or Pantone Number?
    By BobA in forum Africa Twin
    Last Post: 21-07-06, 04:43 PM
  5. Exhaust Paint?
    By Dave O in forum Transalp
    Last Post: 29-12-05, 04:26 PM
