Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Tool Tube on a 600 TA
    pdsquire's Avatar
    Sep 2008
    Surrair
    Re: Tool Tube on a 600 TA
    Quote Originally Posted by Steve T View Post
    All in all a very satisfying afternoons bodging .
    WTH?!?!?
    If that's bodging, anything I could do is butchery!!
    That's a lovely job. Good work.
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    RidingAlongOnACarousel
    Quote Originally Posted by pdsquire View Post
    WTH?!?!?
    TY, your too kind
  4. #13
    Titch's Avatar
    Titch is offline Senior Member
    Feb 2009
    Oldham, Manchester
    Quote Originally Posted by kitped View Post
    I can bring some more in but with a sudden increase in the US shipping cost they will now be £14.00 + £2.25 postage if anyone is interested please let me know
    Hi Kitped, you may remember that I asked for one from you on the original posting about the tubes, so please put me down for one, as per previous request.
    Titch
  5. #14
    Titch's Avatar
    Feb 2009
    Oldham, Manchester
    Titch
  6. #15
    Steve T's Avatar
    Oct 2004
    Small note to add to the fitment of the tool tube - always remember to check your angle-of-dangle at least twice!
    I'll explain - yesterday, when taking in the view from some forest roads, I encountered a slightly deeper than normal hole in the track. Nothing overly huge, but a bit bigger than the others I'd ridden through that afternoon. Anyway, this pothole produced a rather worry "crack" noise as we hit the bottom of the hole. I pulled over to see what was hanging off / broken, and found none of those things. What I did find was what I refer to as a witness mark on the alloy chain guard .
    Yep, you guessed it - the plate the tool tube was mounted on was approx 2mm too far inboard, and when the rear shocker compressed a bit more than normal as I went through the pot hole, the two bits of metal came into contact with one another.
    Needless to say the problem has been sorted with a bit of grunt and elbow grease, but note to self - dont just check the angle-of-dangle by eye, use a plumb line and look for "interference" points .
    And no, I didn't take photo's of the mis-alignment - far too embarrassing!
    Just thought I'd share the knowledge.
    Steve T
  7. #16
    Reizendeben is offline Junior Member
    Aug 2010
    Holland
    Hi, do you still have those tubes ??
    Regards Ben
  1. Tool Tube Photos Thread?
    By Zenarchy in forum Africa Twin
    Last Post: 19-12-10, 08:28 PM
  2. tool storage tube
    By tramp in forum Bodgers Corner
    Last Post: 09-01-10, 10:52 AM
  3. Tool Tube Ops Canister
    By Traveller in forum Mechanical Advice
    Last Post: 25-01-09, 09:46 PM
  4. Tool Tube
    By TanisWolfbane in forum Mechanical Advice
    Last Post: 18-01-09, 10:30 PM
  5. Tool Tube
    By romeo one in forum Mechanical Advice
    Last Post: 20-08-08, 10:23 PM
