Results 1 to 10 of 13
Thread: help help bloody transalp speedo
    running biker is offline Junior Member
    Sep 2009
    kent
    Unhappy help help bloody transalp speedo
    can any one help i have a 2003 transalp and the speedo has packed up i put a drill on the cable and the clock worked ok i checked the plastic cog in the drive and that looks ok what else could it be im desperate
    Bolton, Lancs.
    Re: help help bloody transalp speedo
    Clean all the old dry grease out of the drive and re-assemble with fresh grease, . . . make sure the tabs on the big washer are contacting with the drive properly, they can get bent out of position when fitting the wheel.
    Sep 2009
    kent
    thanks mate do you know how easy it is to get the metal disk out as i couldnt work it out as i do have a replacement
    thanks
    Bolton, Lancs.
    The outer tabs locate in the hub, just a tight fit, so will have to be 'prised' out with a screwdriver or similar.
    Matty22's Avatar
    Matty22 is offline Member
    Sep 2009
    Leeds
    Hey Mate with mine i found that it was the connection between the drive arm on the wheel and the cable. A tiny piece of metal had broke off thus not working, as this drove the cable around.
    Try that?
    Mat
    phil w's Avatar
    Cardiff
    Mines just packed in too... Crap Honda speedos
    It seems that the Speedo drive is the weak spot on Hondas, I had a few go on my CB500 & CX500's
    Mudwiz's Avatar
    Speedo?
    Not a real worry!
    veodoble is offline Senior Member
    Nov 2008
    Barcelona
    It happened to me one month ago, here are my conclusions:
    first, to check out what is not working, cable or gear, just take out the cable out and spin the wheel. If the little metal piece spins, it is the cable. If not, it is the gear.
    Ok, so it's the gear. Then you take it out but seems OK. It's not! If you had the chance to compare it with a new one, you'd see that it has prematurely worn out in the lower area, not the tabbed one. So, the white gear is shorter than it should be, so it doesn't reach the metal tabs in the hub, and consequently it doesn't spin. You have to buy a new one, end of story.
    Then you take out the aluminium casing, and bath it in gasoline for some time. With the help of a brush, clean it as much as you can, so that mixup of grease, nylon powder and crap flies away. Once everything is totally clean, put grease to the top, insert the new white gear, mount the wheel, etc. Don't forget to grease up a bit the cable itself, given that you're already dirty with grease, so it takes longer to snap.
    Hope it helps!
    Jeffrey is offline Member
    Jul 2007
    Andover Hampshire
    Spot on V.
  1. Transalp Speedo Drive Repair
    By ladder106 in forum Transalp
    Last Post: 15-09-09, 11:16 AM
  2. bloody cdi!
    By cool dude in forum I'd like to introduce myself....................
    Last Post: 29-03-09, 08:28 PM
  3. Broken Transalp Speedo
    By Highlander in forum Transalp
    Last Post: 27-01-09, 06:51 PM
  4. replacement speedo for 2001 transalp.
    By sam h in forum Transalp
    Last Post: 30-12-08, 08:01 PM
  5. Bloody xrv'ers, they're everywhere
    By Whealie in forum Chatter
    Last Post: 14-12-08, 08:10 PM
