Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: locknut for rear wheel adjustment?
    holmfirth
    Re: locknut for rear wheel adjustment?
    Quote Originally Posted by jarl View Post
    What's wrong with the twin nuts? It's a bit fiddly, but it works....
    no problem at all
    phil w's Avatar
    Cardiff
    Adjust the chain on an XR.. then you'll see
  4. #13
    MandoBear's Avatar
    Herefordshire, England
    I had the loan of a Suzuki SV650 a few years ago. As I recall, that used nyloc locknuts on its chain adjusters - so Suzuki obviously didn't see a massive problem. I would say if you're going to use them, check them regularly (at least every time you adjust the chain) and go for stainless ones from somewhere like Stagonset so you won't have corrosion worries. It's always a good idea to check wheel alignment when you adjust chain slack anyway - once you get the hang of it, it only adds a few minutes to the job, and gives peace of mind.
  5. #14
    japes1275's Avatar
    japes1275 is offline Senior Member
    Jul 2009
    Lincoln
    My BSA has the old style nylock nuts. It is after all the tightening of the wheel spindle that stops any movement. If that came loose the wheel could still move backwards even with the adjusters locked up, though not much on the lefthand side due to the chain.
    Can't really see any major problem with the lock nuts though.
  6. #15
    Yahoo's Avatar
    Yahoo is offline Need a job
    Nov 2008
    Drifting...
    Can I stick my head out again? That'll teach me for asking silly questions when I'm bored at work, eh?
    You guys scared the *%$ out of me with the talk of ''death'' and ''big repair bills'' so I think I'll stick with the 2 nuts.
    Strange to see how peoples opinions differ though. Some would'nt do it if you paid them and others said it'll be allright. Interesting. I suppose it comes down to different experiences and the like.
    Anyhow, enough talk about my nuts. Cheers for the advise and warnings, as usual XRV rocks!
  1. Replies: 2
    Last Post: 02-06-08, 11:08 PM
  2. rear suspension adjustment
    Last Post: 23-05-07, 07:23 PM
  3. Rear suspension adjustment
    By ddcristi in forum Africa Twin
    Last Post: 02-09-05, 06:28 AM
  4. Rear Brake Adjustment
    By miggy in forum Africa Twin
    Last Post: 06-03-05, 06:12 AM
  5. rear shock adjustment
    Last Post: 20-08-04, 05:41 PM
