Results 1 to 9 of 9
Thread: XL650 Transalp European headlight needed
    markymark is offline Junior Member
    Apr 2009
    stafford
    Does any one have for sale a headlight for a transalp 650 which is from a bike in europe (the arrow on the headlight will point to the right)
    I am willing to buy or swap for a UK headlight.
    The reason I need is that I'm living in Holland and in order to keep my bike whilst im here I have to get it tested under dutch regs.
    Cheers Mark.
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    Re: XL650 Transalp European headlight needed
    was under the impression the trans alp 650 had non directiomal headlights
    Apr 2009
    stafford
    I didnt think so either but if you put your lights on normal beam youll see on the left the pattern is slightly higher i guess to illuminate the pavement (and pedestrians)
    Maybe You can get international ones but I had a surf and couldnt find anything.
    I had no problems in France last year, I have not even noticed the left being higher than the right.
    Take the bike to a tester and get it checked as is before forking out for a new front fairing.
    Yes the Light unit is the main mounting for the rest of the fairing.
    Apr 2009
    stafford
    I did contact the test place and they said that the beam had to pick up on the right not the left to pass the test.
    I asked if I could use tape to block the light but they said it had to be permenant.
    I think your ok just travelling through europe as most people dont even notice it.
    Quote Originally Posted by markymark View Post
    They would say that but,
    Have they actually tested it to see if it does indeed need another unit?
    Apr 2009
    stafford
    Yeah u can see the beam spread and I checked on the goverment website and it even had a diagram of how the beam spread should look, I guess its a common problem.
    Apr 2009
    stafford
    Is that right that I have to replace the complete fairing to change the head lamp?
    Check with the local Honda dealers to see if they have them in and look at the difference, As I say it is a major part of the fairing, it mount to the bike frame and the fairing side panels mount to it.
  1. Suitable stickers for xl650 transalp
    By chris1201 in forum Transalp
    Last Post: 18-11-09, 09:10 PM
  2. xl650 headlight beam diverter?
    By tramp in forum Transalp
    Last Post: 05-08-09, 05:08 PM
  3. Wanted: Wanted transalp european headlight
    By wobblemonster in forum For Sale / Wanted
    Last Post: 29-08-08, 02:31 PM
  4. FOR SALE: 2005 Transalp XL650.
    By CraigMc in forum For Sale / Wanted
    Last Post: 26-07-08, 11:34 AM
  5. XL650 TRANSALP BY BOANO PICS
    By Unmutual in forum Transalp
    Last Post: 03-01-07, 10:08 PM
