Results 1 to 10 of 13
Thread: Wrong chain info in Haynes
    Windmill John's Avatar
    Oct 2008
    Just got back from bike show at SOE Showground. Took my chain info from Haynes: 525 110 links.
    Thank god the guy there knew his stuff, should have been 118 links
    Still, he supplied me with 122 to cover all eventualities.
    Just checked my bike, it has 118.
    Mmmm I wonder if I could get 110 on; that'll be a snug fit. I wonder what note it would play if I hit it with a screw driver
    BTW, picked up a brand new Shoei Syncrotec flip up for my wife £50
    Honda Transalp XL650
    BMW R65
    First Honda CB200 in 1978
    Biggest Honda CB750F2 in 1981
    Lots in between
    Lutin's Avatar
    Galway
    Re: Wrong chain info in Haynes
    Quote Originally Posted by Windmill John View Post
    Which model Transalp is it?
    Oct 2008
    Also an XV650V in silver on a 56 plate; ie V6 model.
    Haynes has definitely made a printing error and it appears it should be 118
    Unless it is 110 and explains why chain has gone past wear mark with 118 links!!!
    BMW R65
    Lots in between
    Lutin's Avatar
    Galway
    No, I think it should be 118 links, though in the Technical Specs page I have it listed as 120 links.
    Honda XL650V Technical Specifications
    I will check my '04 machine tomorrow and update the page if it needs it.
    Austin's Avatar
    GARSTANG
    Definitely 118 links. My haynes is wrong too.
    Boris's Avatar
    Oct 2006
    Edinburgh, Scotland
    I remember something being a bit odd when I did my mates TA chain. The box said (say) 122 links and the book said (say) 118 links so I was all set to cut 4 links off. To be on the safe side I checked the old one and low and behold something was wrong as I only needed to take 2 links off. Had I removed 4 there would have been no way it would have fitted. I can't remember the exact numbers but I'm sure you get my drift.
    I'm on the Safe House List
    Austin's Avatar
    GARSTANG
    650 transalp running standard sprockets is definitely 118 links. I have changed chains 4 times and it is always the same
    I bought my chain on the internet and it came as 118 links, With the extra tooth on the front it was extremely tight fitting it but it did fit and is now at the correct tension without any adjustment needed.
    Mervinh's Avatar
    Mervinh is online now Stone Crazy
    Nov 2006
    The dark side of Dartmoor
    mebbe someone should tell mr haynes
    Oct 2008
    Yes, just out of courtesy, even though the manual has been out a while, I'll email Haynes and let them know.
    Bike definitely has 118 links, so I've reduced the new chain to 118 ready for the weekend fitting.
    I remember the first time I did a chain, I counted from the inner link or outer, can't remember which, ended up one link too short
    I now sadly count from both ways.... twice....
    BMW R65
    Lots in between
  1. Chain & sprocket info
    By Alba in forum Transalp
    Last Post: 24-11-08, 01:20 PM
  2. Haynes manual mistake (chain length)
    By Boris in forum Transalp
    Last Post: 15-06-08, 09:56 PM
  3. brake calipers - Haynes has got it wrong
    By Austin in forum Transalp
    Last Post: 06-05-08, 09:17 AM
  4. DID Chain - Wiki Info
    Last Post: 23-07-07, 09:42 PM
  5. Chain adjustment and the Haynes manual
    By billy in forum Mechanical Advice
    Last Post: 14-10-06, 11:19 AM
