Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Clutch Replacement
    Loic's Avatar
    Loic is offline Member
    Reading
    Re: Clutch Replacement
    [QUOTE=dysan;464896]you have to stake the nut onto the end of the shaft after torquing it.[QUOTE]
    Very stupid question and I should know this, (UKtiffy Will kill me for this) but what is staking, I understand it is some method of locking the nut but how??
    And cheers for the rest I'll get on it soonest!!
    Loic
    dysan's Avatar
    dysan is offline Senior Member
    Dec 2009
    Middlesbrough
    [quote=Loic;464898][QUOTE=dysan;464896]you have to stake the nut onto the end of the shaft after torquing it.
    Loic
    Basically hit it with a hammer (my kind of working).
    You need a drift, a piece of metal about the same size as the notch (about 5mm wide). Place on area to bend in and whack it with the hammer.
    2004 KTM 950 Adv
    1983 CBX 750F
    1991 LR Discovery
    1990 300ZX TT
    http://www.lifes-adventures.co.uk
  4. #13
    holmfirth
    Quote Originally Posted by Delboy 777 View Post
    Hows about someone to do it for you ha ha
    Now that would be the expensive bit!
  5. #14
    Loic's Avatar
    Reading
    Quote Originally Posted by T ALP View Post
    All maintanence should be paid for in blood and skin tis the first lore of biking!
  6. #15
    holmfirth
    Quote Originally Posted by Loic View Post
    Exactly! and over the years I must have gone through several square feet of skin and a few litres of blood --------- worth it
  7. #16
    rlkat's Avatar
    rlkat is offline '99 Varadero 1000
    Oct 2005
    North Berwick
    I've just replaced the clutch rod seal in the engine case and noticed the clutch basket was slightly wobbly. Have a look here for a video (IMGP0055 is the clutch basket video) and pics.
    Flickr: rlkat's Photostream
    I've taken it off and I can't see any wear anywhere. Is a slight wobble normal? There are no abnormal sounds when the engine is running but the gear change is a little clunky.
    cheers
    rob
    ps. in image IMGP0059 the top plate is now fitted correctly in the short slot at the top!
  1. . . . and its new replacement!
    By z-weiser in forum Moto Guzzi
    Last Post: 30-09-08, 01:31 PM
  2. Honda FMX650 clutch replacement or service manual
    By cyber gook in forum Dominator / FMX
    Last Post: 01-04-08, 11:36 AM
  3. Replacement for the AT?
    By Shepp in forum Africa Twin
    Last Post: 19-09-07, 08:25 PM
  4. Clutch Cable Replacement
    Last Post: 02-08-07, 09:47 PM
  5. Replacement A/T
    By piguglyshandydrinker in forum Africa Twin
    Last Post: 04-02-06, 11:03 AM
