Electrics are not my strong point butI believe a garage or a battery supplier will have a meter to check for voltage drop they just stick it across the terminals and see how long it takes to discharge to flat.
Chris
charge the battery fully measure the voltage and note it, leave to stand disconnected from everything over night or a full day then re-check the voltage any drop would indicate a duff battery. simples
if the second reading is much the same as the first this would indicated a problem with the bike not the battery.
logical thinking results in logical conclusions
So i have just checked both batteries, the one not in the bike seems to be holding charge perfectly well.
The other seemed ok when i checked it this morning as well, but then i ran the bike for a few minutes and it gained 0.20 V.
will have a good look at the wiring when i get a chance, but it seems like something on the bike is draining the battery.
Ok so i've been monitoring voltages and it seems that if i ride the bike every day it's fine. But if i don't go anywhere for a day or so it struggles to start.
So something is obviously slowly (i checked for any current) draining the battery while the ignition is off.
I'm thinking the easy solution to this might be to fit some kind of isolating switch on the battery. This could also act as an extra immobiliser as well.
Anyone have any experience with this? what is the best way to install it and where should the switch go? etc.
Strange one this, you would think the ammeter to earth check would show the slightest drain. Or could it be a make/break drain somewhere as when the bike is moved or handle bars turned.
Still think the best way to check the battery might be the voltage drop test at a shop, fully charged to flat straight off, I think it will give a better indication of the kind of condition its in.
Instead of using a isolator switch in the past (as they used to be expensive, no idea what they cost these days) ) I have used heavy duty spade connectors, just pushing them together. ------ Chris
Forgot to ask in my reply above and not having read back on the thread----- has the starter motor been checked out could it be starting to have a problem in some way like weak brush contact, don't want to worry you just a suggestion. ------ Chris
You could get a solar charger and connect it when the bike is not in use, that should help keep the battery from draining.
