Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: can too much engine oil cause clutch slip?
    holmfirth
    Re: can too much engine oil cause clutch slip?
    Quote Originally Posted by oggy View Post
    To answer the question - No. Much more likely to be something else - stretched cable, clutch needs adjusting, too much play at lever etc etc. Not really convinced about the oil argument. I use Synta semi-syth 10W/40 - a decent VW car oil - with no issues. I don't buy the argument that bike oil is fundamentally different, but each to his own...
    But the oil that causes a problem for wet clutches has the friction inhibitors in it.
    I had a rotax 500 engine one time with a bad clutch slip I changed the oil to a diesel and it improved right away I just put it down to the detergent content cleaning the plates. ------ Chris
    Cabby's Avatar
    Cabby is offline SOTGATT
    London/Surrey
    The slip you describe sounds exactly like mine a short while before the clutch finally went.
    It would have lasted a while longer if we hadn't been off roading in Dent at the national.
    Price it for a clutch fairly soon.........'course, I could be wrong....
  4. #13
    Quote Originally Posted by T ALP View Post
    The Army used to use Oil Mineral Detergent in its Rotax engines, with no detrimental effects.
    As for clutch slip with too much oil, that is something I have not heard of, however I have heard of clutches being near the end of their life slipping either the plates or the springs, also if they are incorrectly adjusted.
    While pulling the lever in and letting it back out watch the end by the engine to see if it moves smoothly.
  5. #14
    Mar 2007
    Bridport Dorset
    i did find the reciept for the oil change and it looks like semi-synth car oil has been used.
    that could be the prob,am also going to check adjustment to see if that makes a difference.
  1. Clutch slip ?
    By tonion in forum Dominator / FMX
    Last Post: 20-11-09, 08:17 AM
  2. Clutch slip
    By BigGun1 in forum Transalp
    Last Post: 21-11-08, 11:14 PM
  3. Slip-on end can for xrv
    By Kjell Lindberg in forum Africa Twin
    Last Post: 02-02-08, 11:47 PM
  4. Miss Whiplash - jerk jerk, slip slip
    By KirriePete in forum Dominator / FMX
    Last Post: 16-11-07, 02:47 PM
  5. Anyone ever heard of Air Age exhausts (slip on) ?
    By darthDassie in forum Africa Twin
    Last Post: 24-11-06, 11:32 PM
