Results 11 to 20 of 24
Thread: Fuel economy info
    holmfirth
    Re: Fuel economy info
    Quote Originally Posted by Delboy 777 View Post
    I do, but then multiply bt 4.54 to covert to mpg. Am i anal ??...... probably.
    Likewise -------- its the proper way you know we're british!
    Chris
    dubhe's Avatar
    dubhe is offline Senior Member
    Mar 2010
    Norwich/Portsmouth
    I divide by .22, one less digit to press into the calculator - efficiency all the way
  4. #13
    Delboy 777's Avatar
    Delboy 777 is offline Senior Member
    Apr 2010
    MORAY
    "I arrive. I see... is possible. I go fast. I WIN!" - Valentino Rossi
    57 plate Transalp with loads of bits added on. SOLD
    11 plate Triumph Street Triple "R"
  5. #14
    I have a program on the lap top that works out the fuel consumption in miles per litre, cost ETC.
    I added a couple of fields to covert to MPG and to give the Approx tank range.
  6. #15
    Delboy 777's Avatar
    Apr 2010
    MORAY
    Well thats why i needed to know the figures, dont want to run out of jungle juice in the middle of nowhere
  7. #16
    rizerdibo's Avatar
    rizerdibo is offline Senior Member
    Oct 2009
    Tunbridge Wells
    Quote Originally Posted by tim332211 View Post
    Just thought I would share a bit of info with you all.
    I have a Transalp 650 year 2000 model and am now getting increased mileage (reduced fuel consumption) after doing the following.
    • Installing a K & N air filter (better breathing and more guts at higher revs).
    • Changing the front sprocket to 16 teeth .
    I now average 60mpg (was 55mpg). These are fairly accurate figures, measured after filling the tank many times. My GPS also coresponds with the bike odometer within 1%.
    The higher gearing also makes for more relaxed cruising on faster roads.
    Regards
    Tim
    Might have to try this. My average is 50/51 MPG and I don't think I ride that hard. MPG is my only problem with the bike really. Apart from that
    Rick
  8. #17
    fat-mal's Avatar
    fat-mal is offline Senior Member
    Mar 2008
    caerphilly wales uk
    I am noticing that we still check the Economy in terms of M.P.G.
    It should be easier to work it out as M.P.L. As we buy fuel in litres and do x amount of miles for every one we fill up with.
    You are right but us elders can relate to the real money of gallons and pounds per square foot. fat-mal
    PS Just cant get my head round popping out for a swift 568 ml.
    '08 XL700v
    ."Don't take life too seriously;nobody gets out of it alive."
    -- Elbert Hubbard
  9. #18
    Quote Originally Posted by fat-mal View Post
    I still miss the £.s.d money.
  10. #19
    holmfirth
    Iv'e probably got some somewhere if you're desperate
    Mind you if I hang on I might be able to buy a new 1970 triumph bonnie again for £426 5s 3d
    Chris
  11. #20
    Gadget's Avatar
    Gadget is offline Member
    Feb 2007
    Lancashire, N.West UK
    I might try the mods aswell. I usually get 46-48mpg, though I do ride with spirit. I notice that as soon as I top 80mph it seems to drink fuel like mad and drops as low as 40mpg.
    Perhaps I'll start with the filtre and see if that makes a difference before putting another cog on!
  1. Fuel economy
    By 1965paulh in forum Varadero
    Last Post: 20-04-09, 10:44 PM
  2. yet more fuel economy questions
    By juscrooky in forum Dominator / FMX
    Last Post: 25-11-08, 10:27 AM
  3. Fuel economy revisited
    By 24ftlb in forum Transalp
    Last Post: 17-04-07, 04:16 PM
  4. what fuel economy can i expect.
    By mitch in forum Transalp
    Last Post: 17-09-06, 09:10 PM
  5. fuel economy
    Last Post: 05-10-04, 09:08 PM
