Re: Front Brake - Normal??
Originally Posted by
piguglyshandydrinker
I reckon the 650's brakes are fine for the bikes' capabilities - need anymore & I think you need to look at your riding style
Gotta say, I had no probs last year in the Dolomites and believe me, I was testing the brakes on some of those bends....
Check that the brake pistons move freely when you squeeze the lever & push them back in.
Change the fluid (with pistons pushed fully in).
Check that they are stock pads (give them & rub over with sandpaper if they are - including the crap from the central groove) or change them.
Do the calipers slide freely on the anchor brackets - lube the pins with red rubber grease.
Change brake hoses if you want (with fluid change) - although they should be fine (how many car owners change flexi brake hoses after **years?)
Personally, I would drop the fluid as others say and see if that sharpened matters up, the TA brakes do have a habit of seizing up when not used and I would guess that age can also cause the odd problem in this area too?
steveR
Project Red KMX200
