Results 11 to 20 of 29
Thread: Transalp 600 centre stand question
    GilesMDavis's Avatar
    GilesMDavis is offline Senior Member
    Oct 2009
    Wales
    Re: Transalp 600 centre stand question
    Hmmmm. Seems like I need to practice my technique.
    I'll reattach some of the rear bits at the weekend and let you know how I get on.
    Bolton, Lancs.
    I find it easier to use my left foot on the stand, left hand on frame by tank/side panel, right hand wherever comfortable.
    Then lift and pull backwards, if it don't go up first time let it 'bounce' down and pull up and back immediately, using the bounce back to help.
  4. #13
    Windmill John's Avatar
    Oct 2008
    Quote Originally Posted by slickmouse View Post
    My stand is seized pretty much solid, I recon it needs heat but would take a lot of work to do so have left it alone.
    I think it was an optional extra anyway.
    Slickmouse, you're scaring me!
    Make sure I never buy your bike!
    Get it sorted now, before the stand permanently becomes part of the frame!
    Soak it in penetrating oil for at least a week each day.
    Carefully apply heat to the two pivots.
    Loosen the bolt partially and either hit the end of the bolt with a copper hammer, or possibly use a brake pin remover shaft slightly thinner than the stand shaft and drive it out.
    Swearing will be involved, sweating too
    Every time I remove a bolt from the bike, I always copper grease it on return.
    When you get the shaft out, emery it, brake clean it, thoroughly cooper grease it and get it back in.
    So, the next time your oil filler gets stuck, are you never going to change the oil?
    Sorry for the sarcasm
    Honda Transalp XL650
    BMW R65
    First Honda CB200 in 1978
    Biggest Honda CB750F2 in 1981
    Lots in between
  5. #14
    pdsquire's Avatar
    Sep 2008
    Surrair
    Quote Originally Posted by Windmill John View Post
    Eh? I thought if it didn't come off that means the oil doesn't need changing.
  6. #15
    Oct 2008
    Quote Originally Posted by pdsquire View Post
    You must be right.
    It's like a maintenance free battery, never needs to be topped up
    There is no need to change your oil, it's like a self fulfilling prophesy.
    Oil gets old and thins, but more metal comes off your engine, thereby thickening the oil again. See, no need to change oil
    BMW R65
    Lots in between
  7. #16
    You must be right.
    That is why the shops charge so much money.
    Anyway it is a Honda so it should run fine with old deep frying oil in the engine.
  8. #17
    Rothar is offline Junior Member
    Sep 2009
    Dublin
    I roll the rear wheel of my 600 Alp up on to a piece of wood (regular 2inch by 4inch builders wood). With the rear wheel higher up it makes it much easier to put the bike on the centre stand.
  9. #18
    slickmouse is offline Banned
    Feb 2010
    Scotland
    Thought I'd best reply lol
    My bike is pretty minted in fact had someone at the garage the other day wanting to buy it! The centre stand really doesnt concern me but its always on my to do list and one day it will, I did take off the bolt no problem and release the springs but i just know its gonna be trouble!
    Doing the scottoiler at the weekend so might try harder then as long as the shines
  10. #19
    Oct 2009
    Wales
    Quote Originally Posted by Rothar View Post
    Genius idea. I tried the everything else, to no effect. Although I had just filled up
    Will give it a go tomorrow. I've taken all the bodywork and crashbars off tonight. She appears to be held together with Araldite and zip ties...
  11. #20
    Quote Originally Posted by GilesMDavis View Post
    It beats having to undo all the screws and bolts.
  1. Replies: 6
    Last Post: 11-06-10, 07:12 PM
  2. Wanted: centre stand, crash bars-transalp 650
    By Yahoo in forum For Sale / Wanted
    Last Post: 14-11-09, 09:21 PM
  3. '94 Transalp Centre Stand wanted
    By petterdiesel in forum For Sale / Wanted
    Last Post: 20-04-08, 02:17 PM
  4. Best Centre Stand for Transalp XL650V
    By BuckarooBanzai in forum Transalp
    Last Post: 21-08-05, 03:46 PM
  5. Transalp Centre stand
    By Dave O in forum Transalp
    Last Post: 13-07-05, 09:36 PM
