Haven't bothered with the HCR but the Lube Tube is great!
Reckon it takes 30k miles to break even on a Scotoiler vs just replacing c&s every 10k.
Q is, can you be bothered oiling ur chain any other way to help it get to 10k. Otherwise it may only do 5/6k, in which case you need a Scotoiler!
Originally Posted by
raymo
+1 here they are a pita to initial set up and folk let then run out so have a bother priming and getting messy.... fitted the high capacity resevoir before I did TLD 2000 mile.. recon its got 6000 left before I have to spent 10 mis to remove number plate and fill it... any one with a scotoiler should fit the HCR worth it
Sent from my iPhone using Tapatalk
