Having big problems with this, seem to have an airlock I cant sort?
Have managed successfully to get fluid going through well 3 times with lever tightening up, with only very tiny bubbles coming into the fluid bottle at the bottom. Have then closed bleed valve up but cannot get enough fluid pressure to pump piston far outwards as need to replace it. Now cannot get fluid moving down through master cylinder at all even though can get rid of a few big bubbles through bleed tube now and again.
I have not let cylinder empty so letting air in through the top.
Any ideas?
