Results 1 to 9 of 9
Thread: Cost of second ignition key
    Jose is offline Junior Member
    Jun 2010
    Between the mountains and the sea
    Hi
    If I buy an 04 bike with only one key, what will it cost me to get a spare? I'm assuming it will be expensive, and only available from a dealer, but does anyone know the actual cost?
    Thanks.
    pdsquire's Avatar
    Sep 2008
    Surrair
    Re: Cost of second ignition key
    The key is £17 from Honda. Take it to get cut, then take it back to Honda and they'll charge you half an hour's labour to programme it (c£30). If you leave it with them they'll charge an hour and charge for cutting it too.
    Austin's Avatar
    GARSTANG
    Quote Originally Posted by Jose View Post
    Hi
    Thanks.
    The keys themselves aren't much - the cost of a blank and cutting it. David Silver's sells them - have a look there. Its getting the thing coded to your ignition and HISS system that costs. Should be an hour or so's labour as it is a tank off job to get access to the relevant wiring. AFter that I think it is a 5 minute job to get the ignition into coding mode and code the keys. If you are doing one I would get another 2 or 3 done at the same time. I think you can have up to 4 keys coded to the ignition.
    pdsquire's Avatar
    Sep 2008
    Surrair
    'tis true!
    Good tip. It costs no more to programme three than one.
    Quote Originally Posted by pdsquire View Post
    'tis true!
    That is a Total of Four Keys, if it has the first two registered then you can only get 2 more cut.
    Austin's Avatar
    GARSTANG
    I thought that when it went into programme mode it basically cleared the memory of all keys (except the one currently in the ignition) and you could then add up to another three.
    Steve3 is offline Member
    Apr 2010
    Gloucester
    Just had a spare done for my 650V4. Key cost £22, 30 minutes labour for programming (£27), plus £2 for a local keysmith to cut it.
    piguglyshandydrinker's Avatar
    East Lancs....
    Yep, a total of four keys at any one time.
    Orinoco's Avatar
    Orinoco is offline Womble
    Apr 2008
    Rochester, Kent, UK
    If you buy that 04 bike from a dealer, make them pay........
  1. The cost of stupidity is...
    By Buggles in forum Chatter
    Last Post: 20-04-09, 04:54 PM
  2. The cost of insurance
    By cookingfat in forum Chatter
    Last Post: 19-07-08, 06:37 PM
  3. what'sthe cost
    By Austin in forum Pre 2008 National Meets
    Last Post: 05-09-07, 08:41 PM
  4. 8k Servicing Cost
    By pete07bikes in forum Varadero
    Last Post: 02-05-07, 07:34 PM
  5. The cost of kids kit!!!!!!
    By alpslapper in forum Chatter
    Last Post: 21-11-06, 08:38 PM
