Results 1 to 10 of 14
Thread: TA 600 Headlight problem
    GilesMDavis's Avatar
    GilesMDavis is offline Senior Member
    Oct 2009
    Wales
    Before I head to the garage I wonder if the xrv collective wisdom can help.
    Well, my headlight doesn't work.
    Hi or low (but the dash indicators all come on).
    The fuse is intact.
    The main bulb element looks OK (I think)
    The trouble seems to be at the tab at the back of the bulb, which is corroded and the block it connects into has melted where that tab goes in.
    (I am trying to upload photos to make sense of all this)
    Anyone got any bright ideas of what it might take to repair it?
    1996 Transalp XL600V
    2004 Deauville NT650V
    Oct 2009
    Wales
    Re: TA 600 Headlight problem - pictures
    Bulb filament looks OK...
    Name:  Bulb looks OK.jpg
    But connector is corroded...
    Name:  Corroded connector.jpg
    And the block has melted...
    What's that all about then?
    raymo's Avatar
    aberdeenshire Scotland
    looks like a bad connection
    i.e. not clean....
    so has resistance and given the old current *current * resistance = watts in the form of heat you get melt down..
    in simple terms the current did not light the bulb, but became a heater in the poor connector... clean the bulb contact and replace the melted bit
    Ray
    XRV 650R RD03 1989
    The Longest Day Rider 6
    Oct 2009
    Wales
    When you put it like that it sounds obvious
    I'll give it a go tonight.
    Giles
    Oct 2009
    Wales
    Worked like a charm
    Thanks for the encouragement, saved me a garage bill and made me very happy. And safe.
    raymo's Avatar
    Quote Originally Posted by GilesMDavis View Post
    Worked like a charm
    well done engine out next week?
    XRV 650R RD03 1989
    Grendel's Avatar
    Southampton, Hampshire
    Probably a bit late now but when you do change the bulb put a 80W Halogen one in. It will make a great improvent on the standard light. (Just dont tell the plod)
    My TA 600 Page:
    Southampton Safe house
    Titch's Avatar
    Titch is offline Senior Member
    Feb 2009
    Oldham, Manchester
    Quote Originally Posted by Grendel View Post
    OOOOOOO, Grendal.... Naughty naughty
    Grendel's Avatar
    Hey it works for me and it wont melt the wiring like a 100W could.
    Must admit i can't see many plod saying remove that bulb because you have become too noticable on the road
    My TA 600 Page:
    What would be the difference to point out "Hey look I have an 80 Watt bulb"?
    One bulb of 80 watt gives out more light that a 55 watt bulb, but you see a lot of bikes riding around with headlight and 2 spot lights on giving 165 watts of light and no-one complains about those, unless they are maladjusted.
  1. headlight problem
    By bumpkin62 in forum XR
    Last Post: 20-08-09, 12:38 PM
  2. New Headlight
    By Daz Max in forum XR
    Last Post: 20-06-09, 11:46 AM
  3. 1990 XR 250 Headlight Problem
    By rompn8 in forum XR
    Last Post: 27-04-09, 05:31 PM
  4. xr 400 headlight
    By seedy in forum XR
    Last Post: 15-01-09, 09:07 PM
  5. What to do with my headlight
    By sgoaty in forum XR
    Last Post: 30-08-08, 06:17 PM
