Found myself some s/h Honda 650 transalp panniers and pannier rack. Now the problem is how to fit the rack to my bike without instructions.
I've had a go and I'm struggling to work out how the thing bolts to the frame under the seat.
- Does anyone have any pics of the pannier rails on a 650 without the panniers on (and ideally without the seat on, either)?
- Better still does anyone have any guidance to offer, or the Honda Fitting Instructions?
(Note panniers and rack are from a 2004 bike, mines a 2005. Does that make any diference?)
I'm fairly confident I've worked out which bolts it fits on, but can't work out with the front one (each side) whether the pannier rail sits on top or underneath the existing bolt, and whether there should be an additional rubber spacer for the pannier rail. The rear one each side is more problematic, as the bracket from the rails is a shallow U shape section (with square corners) and looks like it won't sit properly in the existing assembly. Also seems too high for the rest of the pannier rail assembly. I'm wondering whether there should be an extra long replacement bolt (each side) and the rails attach under (rather than above), the rear mudguard, but even then it seems it wouldn't sit well with the captive nut under the frame.
I'm also guessing I'm going to have to cut the panel at the rear of the left hand side cover, but I'm not doing any of that until I'm sure it's needed and in the right place.
