I was just wondering if anyone had changed the spoked rear wheel for a mag type. I live in Blackpool and the sea air is harsh on the rims, and i have to use it every day. Any help would be great.
Thanks Martin
Thanks Martin
The problem you have is that alloy tubeless spoked rims like salt air even worse than steel rims !!. Mine are a bit corroded after our terrible winter but my mates alloys looked like fur balls after a week in the salt roads of London. One way of saving the left side of the rim is to use a Lubeman chain oiler ,as l do, which if set "rich" will give your rim a steady dose of used engine oil ( don't use new oil, a waste). Then WD40 the right side once a week and the rim will out live the engine!. Looks ****ty mind you but hey, you can't have it all!!.
