Recently talked to a disty rep who reckoned you should run oem Tyres as per the handbook but other Tyres as per the tyre manufacturer recommendations.
So I usually run TA Tyres at 32 rear but I ran the last BT45's at 40! Yes 40 psi!
Performed better in the wet, otherwise ran as normal. Best thing was that after high mileage, where it would usually square off in the middle with pronounced edges, it was a lot rounder, less square but equally worn through the thread.
Just put on new Dunlop Trailmax TR71's to try out and I'm running them as per the Manu which is also 42psi.
Sent from my iPhone using Tapatalk
