Hi, I am a newbie to motorbiking in general so forgive any stupidity....
I was washing the bike (proud owner!!) and realised that the rear caliper had a slight amount of play in the back/forward direction.it seemed to pivot slightly around the axle for 1mm or so. When I checked the fiche diagrams i understood that the axle goes through the carrier for the caliper, but then the caliper carrier slots into a tang/groove in the swingarm...the way it feels it is as if the play is coming from the carrier fitting slightly loosely in the swingarm tang. is this normal or is my swingarm tang too wide?
this is on a cold bike, so I dont know if the looseness will be taken up by expansion on a running bike. also the rear brake performs as it should, no noises, jolts, or delay in working.
the bolts fixing the caliper are all tight and true as far as I can check. (I do not possess a torque wrench....yet)
thanks for any advice
R.
