Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: Removing TA650 Emissions Rubbish
    Re: Removing TA650 Emissions Rubbish
    And the verdict having ridden it? No performance difference but it doesn't pop noticeably when throttling off now. Having completely removed the vacuum unit and all the unnecessary hoses and having capped the three spigots (the fourth, the vacuum take-off, is already being used for the Scottoiler), it's much neater under the airbox now.
    Does it make a vast difference to the popping, as that is the only thing that bugs me about mine?
    AlanH's Avatar
    Bristol, UK
    Well, there is no popping at all now that I can detect. To be honest, it wasn't offensively bad before though - just occasionally a bit 'fluffy'.
  4. #13
    At least I now know what the cause is.
    I sometimes wondered if it meant something was about to fail on the exhaust.
    No I have a better Idea I will examine it closer at the next Major service.
  5. #14
    Lutin's Avatar
    Galway
    Really? I quite like it, to be honest. I was wondering if it might be even more noticeable when (okay, "if") I change the silencer. Currently the Fuel Exhausts item looks to be favourite.
  6. #15
    I was only worried by it because I had no idea what the cause was.
  7. #16
    AlanH's Avatar
    Bristol, UK
    ...just in case it was flatulence and not the bike
  8. #17
    Lutin's Avatar
    Galway
    Behave!
  9. #18
    As long as it is the PAIR System causing the popping and not a wrongly set Valve clearance.
  10. #19
    Jul 2008
    Alicante - Spain
    Hi,
    Do you know how much weight you saved removing the PAIR system ?
    Thanks.
  11. #20
    AlanH's Avatar
    Bristol, UK
    Must be about a 400g - not really worth it if all you're after is weight reduction.
  1. Scotland is rubbish
    By Lord Vader in forum Ride Reports and Pictures
    Last Post: 24-08-08, 04:04 PM
  2. rubbish brakes
    By Dominic_the_TA in forum Mechanical Advice
    Last Post: 16-08-08, 08:23 PM
  3. More thoughts on motorcycle emissions
    By russh in forum Chatter
    Last Post: 05-03-08, 11:13 AM
  4. XRV emissions testing
    By doglegdon in forum Africa Twin
    Last Post: 10-06-06, 10:51 AM
  5. Fuel Consumption Vs Emissions Regs...
    By piguglyshandydrinker in forum Transalp
    Last Post: 30-07-05, 10:20 AM
