Re: Ideal rear shock setting?
Not sure which one you have but the TA700 with BT45's runs perfectly on the lowest setting but 1/2turn. This is with 42psi...as per manufacturer.
I think there are 8 half turns on the shock so its a fair difference.
The shock is pretty pants - only rebound adjustment and it aint great at that...max for 2 up and min without load. Hard pushed to notice any real difference inbetween.
Running a high psi in the rear, with soft shock, and normal 30psi front - helps with the front end small bump issue..as in it doesnt absorb small bumps up front.
Also makes the tyre wear better at the rear - doesnt square off so much.
