Strangest thing happened.
I got a rattle that I put down to the chain being dry, it didn't look dry so I cleaned the chain and re oiled it. Still got the rattle.
Took the front sprocket cover off, then slackened the chain so I could check the sprocket. It was very slack on the splines. Cold shiver down spine as I thought the spline was knacked.
Took the sprocket off and was met with a rusty, watery sort of mess on the splines and on the center of the sprocket.
Cleaned it all up and tried a new sprocket (I got a chain and sprocket ready as I have done 12000 miles), the new sprocket fitted perfectly.
Examining the inside splines of the new and old sprocket, it was clear, to the eye that the old splines were very badly worn.
TF that the spline was ok.
Any how, new sprocket fitted AND GREASED, and now the chain is re adjusted, it is almost back to the new setting.
Just for info, chain and sprocket have been on since new.
Might be worth checking yours and putting some grease in there.
