Results 1 to 10 of 12
Thread: Fuel exhaust baffle?
    marvinite's Avatar
    marvinite is offline Senior Member
    May 2010
    Market Rasen
    Question Fuel exhaust baffle?
    Took the baffle out of my Fuel exhaust today on my TA 650 went for a good long ride and apart from it sounding awesome the bike appeared to have more grunt is this possible or am i dreaming?Ive been told its something to do with back pressures which gives the bike slightly more HP.Confused.
    cuchulain's Avatar
    cuchulain is offline Member
    Jun 2009
    County Antrim
    Re: Fuel exhaust baffle?
    I run my Fuel with no baffle as well , it definitly sounds better. I BELEIEVE it gives a better mid range , but i could be talking rubbish. Bottom line i believe it sounds much , much better.
    Have a look at my video .. for a comparison of notes from the exhausts , including the fuel with and without baffle.
    marvinite's Avatar
    May 2010
    Market Rasen
    Thanks enjoyed that.Regards Marv.
    AlanH's Avatar
    Bristol, UK
    Quote Originally Posted by cuchulain View Post
    Where did you get the LED rear light unit?
    You can get them from eBay
    cuchulain's Avatar
    Jun 2009
    County Antrim
    from memory it was ebay , about 40gbp delivered , think it came from ebay germany.
    HTH
    AlanH's Avatar
    Bristol, UK
    Thanks for the info. I'll track one down sometime
    Train Driver's Avatar
    Train Driver is offline melissa theuriau xxxxx
    May 2009
    MK45, Bedfordshire
    Does it clear any panniers and would a trip to the dyno be required
    cuchulain's Avatar
    Jun 2009
    County Antrim
    Good Question , only answer i can give you is 'maybe'
    I installed mine , then ran to France with wifey and the Honda standard rack and panniers.
    I refitted the fuel can three times , the night before we left ,
    and with all the adjustment i could get (there is quite a large amount of adjustment, due to it being a separate link pipe and end can) I only cleared the inside of the pannier frame by a nano millimeter.
    When I returned from france a small amount of powder coat has been worn/melted from the 5 mil spot on the inside of the pannier rack where the exhaust 'might' have touched.
    Does it do for me , HECK YES
    Am I bothered by the miniscule amount of missing powder coat , HECK NO.
    HTH , Cuchulain
    ---------------- Now playing: Guns N' Roses - Sweet Child O' Mine via FoxyTunes
    marvinite's Avatar
    May 2010
    Market Rasen
    Do you run the bike with the baffle out?
  1. Xr400 Exhaust baffle
    By Tony in forum XR
    Last Post: 31-07-10, 05:37 PM
  2. Fuel exhaust dimensions
    By Savak in forum Transalp
    Last Post: 03-06-10, 10:01 PM
  3. xr400 exhaust baffle
    By gav03 in forum XR
    Last Post: 08-02-09, 08:14 PM
  4. XR400´s exhaust baffle
    By Pete Rock in forum XR
    Last Post: 23-02-08, 09:03 PM
  5. Removing Exhaust baffle
    By RapidMK2 in forum XR
    Last Post: 24-07-07, 09:35 AM
