starter relay?
Results 1 to 2 of 2
Thread: starter relay?
    teech is offline Junior Member
    Apr 2011
    Poole
    starter relay?
    Hi,
    my 02 650 was off the road for a short while recently. Got it fixed and rode it around town the other day. Came to it this morning and it wouldn't start and the starter relay was buzzing like a tazer. Checked all the fuses - all OK.
    Had the battery on charge all day and the charger indicates it is full. The lights come on and everything, but all I get is this hard buzzing. Have I got a knackered starter relay on my hands - or is there another explanation?
    Your help very much appreciated fellas.
    Teech.
    Re: starter relay?
    The first thing I would check is ALL the connectors, It sounds like a loose terminal or dirt on the starter motor.
  1. Generic starter relay?
    By Devilkin in forum Africa Twin
    Last Post: 31-05-11, 07:13 AM
  2. Burnt out starter relay
    By bazza in forum Africa Twin
    Last Post: 04-10-10, 09:05 PM
  3. starter relay solenoid
    By The Hunter in forum Varadero
    Last Post: 25-05-10, 08:58 PM
  4. starter relay RD07
    By paulm in forum Africa Twin
    Last Post: 27-07-06, 08:38 AM
  5. Starter relay problem
    By billy in forum Transalp
    Last Post: 10-07-06, 08:19 PM
