Crash proofing rear brake lever - Page 2
Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Crash proofing rear brake lever
    AlanH's Avatar
    Bristol, UK
    Re: Crash proofing rear brake lever
    Quote Originally Posted by jarl View Post
    If the solution is a tool to bend it back out kept under the seat, then that's cool too.
    How about one of the tyre levers you no doubt take with you when off-road?
    KTM 990 Adventure
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    It'll only bend/straighten so many times before it fractures at the pivot, or once if it falls wrong........
    Sent from my HTC Desire S using Tapatalk
    '02 - 650 Transalp
    '92 - VFR750
    '91 - NC30
    (UK spec)
    '08 - 600 Hornet for sale
    (kind of....)
  4. #13
    wilso122's Avatar
    wilso122 is offline Member
    Jan 2012
    United Kingdom
    So now I've mentioned that you know what'll happen next time I go out.......
    The other solution is to fit a rekluse and LHRB, just get rid of the brake pedal completely, hummm might see if they do one for the TA...
  5. #14
    jarl's Avatar
    jarl is offline Senior Member
    Apr 2009
    Bath
    Which is the problem of using a tyre lever.
    As for breaking if it falls wrong, that'll happen irrespective of whether it has a bendy end or not.
    Maybe a spanner will work...
  6. #15
    hotbulb's Avatar
    May 2009
    Cardiff
    Quote Originally Posted by wilso122 View Post
    You've lost me here... could you please explain ? Thanks
  7. #16
    kevinhancock750's Avatar
    kevinhancock750 is offline Senior Member
    Oct 2010
    south of france
    the answer to your problem...............................
    dont fecking fall off!
  8. #17
    wilso122's Avatar
    Jan 2012
    United Kingdom
    Quote Originally Posted by hotbulb View Post
    Its a replacement clutch that works on centrifugal force, as the engine reaches speed it forces a plate to engage drive, usual gearless changes on the way up, at below 1800 rpm it essentially enages a permenant clutch.
    So you can fit that and remove the brake pedal and pop on a Left Hand Rear Brake... Think twist and go on a geared bike... See the picture below (the other bike) and notice no brake pedal
  9. #18
    hotbulb's Avatar
    May 2009
    Cardiff
    Thanks... I thought there was something familiar in the name "rekluse".
  1. Rear brake lever
    By deano in forum Africa Twin
    Last Post: 17-01-11, 11:08 PM
  2. honda xr 125 l3 rear brake lever lever
    By Admin in forum eBay - XR
    Last Post: 16-01-11, 10:00 AM
  3. Folding rear brake lever??
    By barkingbiker in forum Transalp
    Last Post: 04-06-09, 09:21 AM
  4. Bent rear brake lever
    By DaveS in forum BMW
    Last Post: 28-05-08, 06:21 PM
  5. Adjusting rear brake lever
    By flipfly in forum Transalp
    Last Post: 01-07-07, 07:33 PM
