transalp 650 cockpit bulbs?
Results 1 to 4 of 4
Thread: transalp 650 cockpit bulbs?
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    Hi guys..
    well after my Alps little swim the cockpit bulbs have nearly all blown so where do you get them from ...or better still what size watts etc are they..before I take the cockpit apart to replace them ..
    Also anyone know how easy it is to replace the clock? mine no longer works....
    thanks guys..
    alanvendy's Avatar
    alanvendy is offline Senior Member
    Dec 2008
    northants
    Re: transalp 650 cockpit bulbs?
    David Silver Spares - 34908-MB9-871
    David Silver Spares - 34908-GA7-701
    It would appear tey use 2 different types of bulb.
    sorry don't know about the clock.
    Lutin's Avatar
    Galway
    There are two types of bulb in the TA650 cockpit -
    1) Bulb, wedge base (12V, 3.4W) - Part No: 34908-MCB-611
    2) Bulb, wedge base (12V, 1.7W) - Part No: 34909-MCB-611
    You should be able to get them cheaper from a decent motor factors than buying original Honda. Some the online auto electrical sites may well be cheaper again.
    With the clock being part of the tachometer you are a bit stuck. The clock is probably one of the functions of the chip in the tacho that does the, err, tacho thing. What I would suggest is taking the meter assembly off and leaving it in the airing cupboard to see if you can dry it out.
    On the Safe House list. Well, I say safe............
    hotbulb's Avatar
    May 2009
    Cardiff
    Mr Haynes says the instrument bulbs for the TA 650 are 3off 1.7 Watt .. turn signal 2off 3.4 Watt .... high beam indic 1.7 Watt .... neutral indic 3.4 Watt... oil light 1.7 Watt ...immobiliser 3.4 Watt. However, it's not clear what base(s) are used on each bulb.
    Oh, you've beaten me to it...I must type more quickly!
  1. Africa Twin XRV 750 Cockpit Dashboard RD03-RD07a, 88-03
    By Admin in forum eBay - Africa Twin
    Last Post: 18-01-11, 05:31 AM
  2. Honda Transalp all Xenon headlight bulbs H4 501
    By Admin in forum eBay - Transalp
    Last Post: 15-01-11, 03:40 AM
  3. cockpit conversion?
    By paddy in forum Africa Twin
    Last Post: 22-02-07, 08:19 PM
