wont start
Results 1 to 10 of 16
Thread: wont start
    Recycler's Avatar
    Recycler is offline Pleb
    Cornwall
    wont start
    bik started on choke as usual 2day, then died few seconds after turnin choke off. then wouldnt fire at all, turns over fine. havent done any work on it recently 2 disturb wiring or hoses. took a plug from each cylinder, colour was good but seem bit dry. fuel comes out both carb drain screws. after trying again with both keys noticed hiss immobilizer goes out after 2 seconds as it shoul but when i press the starter it flashes intermittently , not bright like a fault code though, any ideas please all? typin on a ps3, so xcuse spellin
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    I had a HISS hiccup after the winter service, v similar actions from the light - sometimes full brightness, sometimes dull & flickering.....
    I stripped/lubed the kill switch starter button & slight improvement then wiggled the connector for the HISS pickup (r/h/s of clocks i think) it's the one with waterproof connector & that sorted it, so lubed it & i think i tightened the female connectors (gently with pliers).
    Been fine since
    Blooming troublesome bike - last time was the headlight bulb went.
    Whatever next
    Sent from my HTC Desire S using Tapatalk 2
    '02 - 650 Transalp
    '92 - VFR750
    '91 - NC30
    (UK spec)
    '08 - 600 Hornet for sale
    (kind of....)
    steveR's Avatar
    steveR is online now Older, but no wiser!
    Jan 2006
    God's own County, Shropshire
    Re: wont start
    Been fine since
    Whatever next
    Dam'n those Honda's for being so ruddy unreliable. You'll be telling me next you have to change the oil or something.
    steveR
    Project Red KMX200
    Grubby Black Vara...
    Windmill John's Avatar
    Oct 2008
    Re: wont start
    Do waggle the kill switch as well. Plus, keep the second key away from the ignition when trying.
    http://www.windmillhillvillage.co.uk
    Off road in Portugal; Cracking Grommet
    First Honda CB200 in 1978
    Biggest Honda CB750F2 in 1981
    Lots in between
    Recycler's Avatar
    Cornwall
    Re: wont start
    Thanks all, will try all that when I get the chance
    Recycler's Avatar
    Cornwall
    Re: wont start
    Yesterday I stripped the fairing and checked all the connector blocks and wiring (visual check as I don't have a multimeter or the knowhow to use one). Gave them all a spray of WD40 - including the HISS connector block. After giving the battery a full charge I tried to start her today with no luck.
    The HISS light no longer flickers though, cheers Phil
    After trying I opened both carb drain screws and nothing came out - so now I'm thinking fuel starvation? I've tried it with the fuel cap off.
    Next plan is to see if fuel tap blocked by;
    1) Sucking on vacuum pipe? Or do I need to pull fuel pipe off tap and press starter?
    2) If no fuel flow: Check vacuum pipe is airtight (no splits etc).
    3) If vacuum pipe is sound then strip fuel tap.
    Does this sound like best next steps? And is the tap serviceable without ordering new parts? I thought there was a thread about it in last couple months but can't find it.........
    4) As a seperate issue; if I want to check for spark, do I take a plug cap off each cylinder and attach a spare plug to each - hold them against cylinder and press starter (leaving original plugs screwed in)?
    Thanks in advance.
    Leigh (& Saltburn!)
    Remove the fuel pipe from the tank & vac pipe from the cyl head, suck on the vac pipe & prepare to catch fuel from the tap!
    If when sucking, if you are constantly drawing air, check the vac pipe for holes.
    If you do get fuel flowing, reconnect the fuel hose & suck again for a few seconds - if you have drained the carbs they will need refilling before she'll start!
    I presume there is fairly fresh fuel in the tank, kill switch is to "run" etc.....
    The taps are generally reliable, when they fail they often go to "always on".
    Test for spark; remove plug cap & plug, reconnect them & rest so the plug has an earth (away from plug hole!) & crank the engine as you would to start it.
    '02 - 650 Transalp
    '92 - VFR750
    '91 - NC30
    (UK spec)
    (kind of....)
    Recycler's Avatar
    Cornwall
    Re: wont start
    Thanks Phil.
    Yes fresh fuel and kill switch on - it wont turn over if off.
    When you say earth the plug.......how exactly?
    hotbulb's Avatar
    May 2009
    Cardiff
    Re: wont start
    Quote Originally Posted by Recycler View Post
    Thanks Phil.
    Just lay the plug on the engine so that the metal body of the plug is in (good) contact with the metal of the engine.
    jarl's Avatar
    jarl is offline Senior Member
    Apr 2009
    Bath
    Re: wont start
    Not on an 'Alp!!! One cylinder will fire as normal, and the plug in the other cylinder will ignite the mixture which blows straight out of the plug hole. It's LOUD. Or at least, that was my experience!
    I would disconnect both HT leads from 1 cylinder and remove one plug. Plug the plug into an HT lead and touch the threads of the plug against the metal of the engine. Then hit the starter.
    Using a new plug is possible, but most the time the coil etc is fine, but the plug is gummed up or worn, so there's no spark. Putting a new plug onto the HT lead will prove that the coil, etc, is providing the energy, but not that your spark plug is sparking.
  1. wont start after rebuild
    By upyourkiltbatman in forum XR
    Last Post: 10-09-11, 03:31 PM
  2. xr600 wont start from hot!
    By Groik in forum XR
    Last Post: 22-03-11, 04:19 PM
  3. Help, wont start
    By bazza in forum Africa Twin
    Last Post: 14-06-10, 09:36 PM
  4. 95 600 ta wont start ??
    By scan in forum Transalp
    Last Post: 25-11-08, 02:31 PM
  5. wont start
    By joe 90 in forum XR
    Last Post: 17-11-08, 11:18 AM
