I'd certainly rebuild or try to source a good used wheel, but I wouldn't go for a stainless rim because it'll increase the unsprung weight. Decent rims (e.g., Akront) should avoid the corrosion problem, but even the standard items should last - my last TA was still very good even after 12 years. D.I.D are supposed to be good, but I suspect the grade Honda used may not be the very best! The gold ones used on the pre-twin disk TA seem to be the most prone to the problem. Mixing metals is always a recipe for disaster - stainless spokes are likely to accelerate the problem (galvanised tensile steel corrodes eventually, putting the alloy of the rim under less pressure as the sacrificial anode).
Well, that's my ten penneth - hope it's of use!
Stig
