Results 1 to 3 of 3
Thread: suspension
    sean's Avatar
    sean is offline Captain unsensible.......
    Mar 2005
    Hastings, East Sussex, United Kingdom
    suspension
    has anyone had their front suspension changed at all? having problems with mine as its way too soft for me(16 stone). i changed from death wings to metezler tourances thinking the tyres were partly to blame but it seems even worse now. played with pressures but no avail. any suggestions? ta sean
    Caffrey - The greatest dog in the world.
    wheeliebin's Avatar
    N/A
    Touratech offer firmer springs 'for improved control'.
    A few washers under the fork top nuts increases the 'preload'.
    The Dominator uses the same rims and tyre sizes but runs 33/36 psi.
    Thicker fork oil would be like increasing the compression and rebound damping.
    wheeliebin's Avatar
    N/A
    Mine's got 10mm spacers in the front forks, rear pre-load has also been increased 10mm (remove battery box for access to shock pre-load collars) and I run 32/36psi tyre pressures.
    Didn't mess about with oil weight or 'air gaps'.
    Bike sits a little taller (not a lot) and rides firmer allround.
  1. Suspension
    Last Post: 23-05-07, 10:53 PM
  2. Suspension set up and sag
    By Pete Rock in forum Transalp
    Last Post: 14-02-07, 04:51 AM
  3. Suspension advice
    By willb in forum Africa Twin
    Last Post: 21-07-06, 07:20 PM
  4. Lowering suspension
    By boboneleg in forum Africa Twin
    Last Post: 11-05-06, 11:30 PM
  5. Suspension
    By DaveS in forum Africa Twin
    Last Post: 05-09-04, 10:14 PM
