Results 1 to 10 of 11
Thread: Inside the gearbox....
    ChrisH's Avatar
    May 2005
    Kingdom of Kerry
    I found this little blighter lurking beneath the first gear pinion on the output shaft..
    Anyone like to make a stab at the reason this (plain) bush ended up in this state, cos it's got me completely bolloxed. Never seen anything like it, looks like it's been eaten... the way I am with this engine, it's probably a TA eating virus. Still I reckon a good dunk in the Atlantic ocean should cure it....
    wheeliebin's Avatar
    N/A
    Yuk, are you sure that came from INSIDE the engine ? Doesn't look like it.
    Even my '49 Triumph engine, run on monograde oil and stood for thirty years, still has clean internals.
    Fatjohn is offline Senior Member
    May 2004
    Bedford, spiritual home of Chav-mobile it seems
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    Doesn't look healthy!!!
    Does the bike have known history? (ie been sat at the bottom of a lake for 2 months!)
    I suppose youv'e dropped the oil, if now what about getting an oil sample carried out, sending pic's of the bush.
    Just for a laugh (not) try sending pics to Honda Tech dept.
    What engine prob's have you had to require a strip?
    '02 Transalp
    '01 Transalp (Transrat)
    '98 Transalp
    '91 NC30
    '08 Hornet (Vanessa's)
    ChrisH's Avatar
    May 2005
    Kingdom of Kerry
    Your views seem to concur with my own! I brought the bike back from the UK in July - went perfectly. Did some miles here until the clutch started getting snatchy, and the engine made queers noises. Stripped it down and found a small lump of hard metal embedded in the oil pump and the clutch basket bush had picked up metal. Everything else was fine!!! So I got a new clutch, bush and oilpump from David Silver (highly recommended - very helpful) then later found this bush when cleaning up the gear shafts. Every other bush in the gearbox is perfect... Consensus round here is that it was a duff bush from the start - can't find any other explanation. There is no sign of anything breaking in the engine, and it doesn't look like it's been thrashed/abused.... My own theory is that somehow some bit of metal got into the engine, oil pressure was reduced and caused the clutch bush to be starved of oil ( feed to the input shaft is via a small drilling in the casing ) and amazingly didn't damage the mains, cams etc. The gearbox pinion bush is unconnected I reckon....You're right Phil, I should have had the oil tested. The crowd I bought the bike off weren't very interested. I'd just like to have some idea of why this happened as it's costing me a bit to repair..... appreciate any thoeries!
    chris v Guest
    Is it small enough to have been 'posted' in the oil filler hole?
    ChrisH's Avatar
    May 2005
    Kingdom of Kerry
    Can't see it really, I think there may be an element of the Friday Special involved? S'pose anything's possible.....
    Recycler's Avatar
    Recycler is offline Pleb
    Cornwall
    Had 3rd gear hardening give in on an XR600, but even then all bushes were fine.
    I've still got 2 bushes and a circlip unused. Let me know if they are any use to you - I don't know if they also fit a Tranny.
    part nos 23432-mk2-000 and 23432-mn1-670
    circlip 90601-107-000
    As PC Plod in Noddy says: 'What we have here is...................a mystery.'
    ChrisH's Avatar
    May 2005
    Kingdom of Kerry
    Thanks Recycler - I ordered the bush from David Silver, just a shame I didn't notice it when I ordered the clutch and oil pump..... another week goes by with the TA off the road. Still it's getting a damn good clean up! I even ground the valves and put new oil seals on them! Don't think even Mr Plod can solve this one, it just better run Ok when it's back together - or I'm gonna tell Tessie Bear and Bumpy Dog, and Bumpy Dog is SO naughty he'll do just the most horrible thing to that bad engine...
    Recycler's Avatar
    Cornwall
    You've got kids too then.
  1. Reaching inside RD07 fuel tap
    By Steve C in forum Africa Twin
    Last Post: 08-01-07, 11:49 AM
  2. And it's Chad coming up on the inside...
    By Hagalaz in forum Chatter
    Last Post: 23-08-06, 09:53 AM
  3. Gearbox ?
    By peterb in forum Chatter
    Last Post: 08-08-06, 07:11 PM
  4. What is inside bar ends?
    Last Post: 01-07-06, 11:02 AM
  5. speedo gearbox
    By rossco in forum Africa Twin
    Last Post: 19-01-05, 08:54 PM
