Results 1 to 10 of 17
Thread: uneven tyre change
    Xander's Avatar
    Jul 2006
    Lichfield
    uneven tyre change
    Hey guys, I had to change my tyre the weekend before last. Anyway I noticed today...that it has not gone on evenly... on part about 8 inches is much "deeper" about a 1cm or so in the rim then the rest.. i have not had this happen before.. i tryed to re-rim it.. twice and it seems to end up the same way.. Funny thing is that i cant even feel it.. any suggestions before I take it to a tyre place?
    Re: uneven tyre change
    Quote Originally Posted by Xander View Post
    Take it half off (one side only) and this time when you put the first bit of bead on, get your knee right on it like you mean it so the tyre goes right inside the well of the wheel and you have more room the other side when the last bit plops on.
    Xander's Avatar
    Jul 2006
    Lichfield
    I think i did not describe the problem right.. I can get the trye on the wheel fine but the a small bit is to deep in well inside the wheel well and wont come out even..
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    Hi Xander, have you tried overinflating the tyre to seat the bead, may need 50psi or more, use plenty of lube.
    '02 Transalp
    '01 Transalp (Transrat)
    '98 Transalp
    '91 NC30
    '08 Hornet (Vanessa's)
    Xander's Avatar
    Jul 2006
    Lichfield
    I did try that.. no lube though... what would be the best type... Ky jelly????? ewwww... but seriously. what would be a good lube?? I never used any lumb to get in on.. oh man i dont like the tone of this post....
    eammonj's Avatar
    eammonj is offline Member
    Aug 2004
    manchester
    I have always used WD40 as a lube on tyres.
    Que loads of posts on how bad Wd is for rubber .
    steveR's Avatar
    Jan 2006
    God's own County, Shropshire
    Seen this before, If I cannot get it to seat with loads of pressure, 60psi.. drop it down to almost nothing and toss the wheel up into the air so that it lands on the tyre and repeat this a few times, rotating the wheel each time. Had to do it on Friday when fitting a new rear. Seems fine now
    steveR
    Project Red KMX200
    Mudwiz's Avatar
    Happened to me just, too. Answer - loads of lube and 70 psi. Used WD40 at first but then with loads of tyre soap (at local bikeshop, and their airline) it popped on OK. Cost me £6 though!
    steveR's Avatar
    Jan 2006
    Quote Originally Posted by eammonj View Post
    Depends on what the rubber is being used for....
    steveR
    Project Red KMX200
    Xander's Avatar
    Jul 2006
    Lichfield
    well of course it is for lubing the rubber so it can be pushed in to the tight rim.and bouncing up and down on while increasing the pressure until things cum right.....
    okay my fault for bring the tone down.. So tonight i will try the lube and bounce thing.. with various amount of pressure..
  1. Tyre change
    By fatowl in forum Transalp
    Last Post: 07-05-07, 12:25 PM
  2. Oil Change
    By DaveS in forum Mechanical Advice
    Last Post: 06-01-07, 09:20 PM
  3. Oil Change.
    By Guzzler in forum Dominator / FMX
    Last Post: 15-11-06, 09:34 PM
  4. clutch change ....how long to change plates?
    Last Post: 03-04-06, 10:23 PM
  5. Uneven tyre wear
    Last Post: 19-05-05, 09:36 PM
