Results 1 to 7 of 7
Thread: Nail - to remove or not?
    Raven's Avatar
    Raven is offline DILLIGAF
    May 2007
    Dorset, England
    Okay, I managed to pick up a nail in my front tyre today, which is a pain as its got another 6000 odd miles left on it . The tyre pressure is still fine, and no air appears to be escaping. As the nail seems to plugging the hole it made, can I leave it in there, or do I risk the inner tube getting punctured?
    Yours hopelessy, James
    2004 Honda XR125L
    2010 Custom Harley - Davidson
    Re: Nail - to remove or not?
    TA's use tubes so if you have a nail and the tyre is not deflating then carefully remove it before it enters the tube
    Raven's Avatar
    May 2007
    Dorset, England
    Cheers Stumpy
    2004 Honda XR125L
    Lumiya's Avatar
    Ziost
    With an inner tube it would go flat if the tube was holed even if the nail was left in where as a tubeless tyre tends the nail would act as a plug.
    Either way remove it as with a tubeless tyre even if it is holed and sealed by the nail you'd rather have it go down in front of you than fly out through rotaional forces when you're doing speed. Especially as it's your front tyre.
    When I was a courier back in '95 I left a nail in the rear of my CX500 and had it fly out whilst doing 80 up the M40 near Oxford, was about 8pm, dark as hell and peeing down with rain...All of a sudden the bike acted as though the rear wanted to overtake the front. I just let go of the throttle and let it slow itself down...Just glad that there was nothing else behind me at that time. If it was my front tyre then not sure the bike would have stayed upright.
    Kymmy
    Raven's Avatar
    May 2007
    Dorset, England
    Well its out, I will just have to keep an eye on the tyre pressure to make sure it hasn't holed the tube.
    Kymmy
    Sounds a bit scary...
    2004 Honda XR125L
    Chunk's Avatar
    Chunk is offline Senior Member
    Jan 2008
    Bournemouth
    Quote Originally Posted by Raven_UK View Post
    It's the best thing to do. Any foreign object in the tyre needs to come out asap. After all, they're the thing that connect you to the road.
    Chad's Avatar
    wickford,essex
    yup deal with it asap
  1. Remove battery on 400 XR
    By KerTz in forum XR
    Last Post: 27-05-08, 05:47 PM
  2. hoofin great nail
    By jabba in forum Varadero
    Last Post: 05-06-07, 09:29 AM
  3. How to remove the jet needle of a AT ?
    Last Post: 21-12-06, 04:56 PM
  4. ....any tips on tyre remove all
    Last Post: 01-08-05, 09:32 AM
