With a huge effort from juniorxr400, I got a set of LM Dakar wheels to install on my XL600R. Has anyone done this conversion before?
Now, the rear wheel was an easy swap.
But the front is a little more challenging. I knew the brake caliper was different, and I thought I had that covered. But nothing about the brake is compatible with my stock fork leg.
The only pic I have of this conversion shows a different brake rotor. All the LM rotors I've seen are solid. But this one with the vented rotor seems to use the stock caliper and fork leg.
Any advice or suggestion would be appreciated.
And a big thank you to juniorxr400!
