Results 1 to 5 of 5
Thread: rear suspension on my xl600 lm
    oldbanger's Avatar
    oldbanger is offline Member
    Oct 2008
    berkshire
    I have a xl600 lm one of the problems i have with this bike is the rear shock is sagging to much now it could be worn but it my be more than this, not knowing much about its history it looks as if it may have the wrong shock fitted as it often strikes the rear mudguard. I'm a about 14 stone though. Dose anyone know the static sag settings i should be looking for on this bike? I have noticed from pictures on the web that other bikes of this model have a higher angled s/arm mine looks parallel to he road when parked is this a problem.?
    Any knowledgeable help is appreciated.
    Stormforce8's Avatar
    Dec 2005
    New Forest - Hampshire-on-Sea
    Re: rear suspension on my xl600 lm
    Can't help with the static sag measurements but I can give you this from the Honda XL600LM Workshop Manual
    Rear Spring - free length - STANDARD 268.5mm.
    Rear Spring - free length - SERVICE LIMIT 265.5mm.
    Damper Compression Force:
    Place the damper rod on a scale and measure the force required to compress the damper by 10mm
    Compression Force 28.5Kg
    If the force required is less than 23.5kg gas is leaking (or has leaked).
    Stormforce8 SmugMug gallery
    Rugged Roads
    Current stable.............
    oldbanger's Avatar
    Oct 2008
    berkshire
    Thanks thats useful info stormforce8, It's seen better days the shock that is. I will have to rebuild it or swap it at some point. I think the spring needs replacing for one that is a higher rate. Its a pain not having ride hight adjustment on this bike.
    The quick fix is to grind the spring it's sounds strange but this has the effect of upping the spring rate, reckon I should aim for around 100mm of rider sag.
    I have around 150mm at present, Not good.
    By the way thats a Beautiful Africa twin I'm jealous
    Apr 2007
    East Anglia-ish
    Also if its the origional spring i think they were all blue,but the measurement will give you an idea
    AND A BIG UP TO IBN BATTUTA
    ADVERTISE HERE.
    Absynth eye drops
    see things in a new way
    oldbanger's Avatar
    Oct 2008
    berkshire
    Had the shock off the bike Mel and the spring is blue and so was the air trying to get it apart, finely managed it and replaced with new oil works fine now but not an easy thing to work on, if anything it's a little to firm now must have a twiddle when i have more time.
  1. Rear suspension links
    By catteeclan in forum Dominator / FMX
    Last Post: 21-06-08, 12:36 PM
  2. xr 400 rear suspension
    By wthirlby in forum XR
    Last Post: 29-05-08, 06:10 PM
  3. rear suspension bearings
    By pancho in forum Africa Twin
    Last Post: 13-08-07, 01:15 PM
  4. Vara Rear Suspension
    By Taz in forum Varadero
    Last Post: 18-06-06, 09:17 PM
  5. rear suspension adjust.
    By gibbo in forum Africa Twin
    Last Post: 18-07-04, 07:55 PM
