Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: Another little problem, Oil light?
    catteeclan's Avatar
    catteeclan is online now Senior Member
    Jun 2006
    Gorleston Norfolk
    Re: Another little problem, Oil light?
    I'm gonna have to take a pic of mine now.
    Same as mine but the lights down the side.
    Next question, is it oil pressure or oil warning.
    If pressure there'd have to be a sensor/switch on the engine.
    If warning I'd guess the only place for a sensor would be the frame tank.
    Gonna go check the wiring diagram now.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
    oldbanger's Avatar
    oldbanger is offline Member
    Oct 2008
    berkshire
    Well I must confess catteeclan it looks dude but every time I go looking I get side tracked i can't find an oil switch and this is the first thumper Honda engine of his this type i have owned. Last time I had a bike with one cylinder it was called a gold star.
  4. #13
    raymo's Avatar
    aberdeenshire Scotland
    OIL light is at the top, switch is near the filter ( on the RD01 ),
    supprised if its not got a switch, but the clocks look standard ( 8k redline on the big V twin though )
    ray
  5. #14
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Quote Originally Posted by raymo View Post
    ray
    What model is that, and it that oil pressure with the switch on the filter end?
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
  6. #15
    raymo's Avatar
    Model is the XLV750R RF RD01
    the oil switch is near the filter, note the silver pipe is the feed to the hydraulic tappets
    the top light is the oil pressure light in the previous post, suspect the speedo nacels are common to most XLs hence the light, as I said would be very supprised if there were no pressure switch on your engine.
    I have removed the air scoop that covers the front pot to aid cooling to the rear, so you can see the filter and switch
    ray
  7. #16
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Mine's a XL600LM-f and there's no mention of an oil warning light in my workshop manual.
    Is it possible you're got a XLV speedo on your bike?
    When I got this one I got it as a non runner, yeap the owner ran it out of oil so a warning light wouldn't be a bad idea.
    Be good for all the big singles as they all use oil.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
  8. #17
    raymo's Avatar
    Quote Originally Posted by catteeclan View Post
    The XLV750R tach has the red line at 8000+rpm, think the singles are 7000, so if some one has slotted the XLV clocks on that may be an indication?
    my XLV does not use oil, but I would not feel comfortable without an oil pressure light!! rather the light came on when there was an oil problem than the motor exit stage right
  9. #18
    Krtek's Avatar
    Krtek is offline They say I talk too much.
    Arnhem, the Netherlands
    Quote Originally Posted by oldbanger View Post
    There you go catteeclan one clock as fitted to my XL600L rgm, anyone put some light on it is it standard or is i a clone?
    Well, it's certainly different from mine (standard XL600R european version). Mine goes to 160 km/h, not 200, and it has four lights on the right but they are turn, neutral and high beam, the one on the bottom is not used.
  10. #19
    oldbanger's Avatar
    Oct 2008
    berkshire
    Red face Re: Another little problem, Oil light?
    Well had another look today but didn't solve the mastery i reckon someone has fitted a clock from a Translap or something not going to worry about it anymore
  11. #20
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Bet you're right. Looks the same as the XLV clock to me. Shame coz it'd be nice to have one on my NX.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
  1. Brake light problem
    By malone in forum Africa Twin
    Last Post: 02-05-08, 09:03 AM
  2. Brake Light Tail light Question
    By conkers in forum Africa Twin
    Last Post: 25-11-07, 04:07 PM
  3. fog light now too
    Last Post: 29-06-06, 03:23 PM
  4. Light problem!
    By Jouman3 in forum Africa Twin
    Last Post: 16-08-05, 10:22 AM
  5. Rear brake light problem
    By miggy in forum Africa Twin
    Last Post: 01-12-04, 09:47 PM
