Results 1 to 10 of 13
Thread: help xl250r wiring
    softerz is offline Junior Member
    Nov 2008
    wisbech
    help xl250r wiring
    hi guys and girls,
    wondered if i could dive in to the pool of knowledge on here! i have a 84 xl250r fitted with a 1981 cb250rs engine! it was on the road but since the rebuild i have decided to just use it for pratting about on.
    what do i need to connect. i would like it to ruin with minimum wiring? ideally with the kill switch still wired in! the guy who had it before me mucked the wiring loom about so the colours dont macth the diagram which is always handy!
    thanks
    wayne
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Re: help xl250r wiring
    For sparks you'll need to use the black/red from the alternator, this is the power supply,
    2 wired multiplug front the clutch side of the engine, this is the pulse generator, (blue/yellow and green)
    Black/yellow from the coil.
    Black/white from the kill and ign switches.
    Green is the earth wire.
    All these wires go to the CDI. Hopefully you've still got the multipugs with enough wires on it.
    Connect these up but leave the black/white for now. If all is working and correctly wired you should have sparks.
    The kill/ign cuts the engine by shorting the black/white wire to earth.
    Hope this helps.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
    Nov 2008
    wisbech
    thanks a lot. what connects to what though. i have a rough idea but dont want to chop the wiring loom unless i am confident?
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Black/red from the alternator to CDI,
    Multiplug from clutch side to CDI, (2 wires, blue/yellow and green)
    Black/yellow from coil to CDI,
    Black/white from ign and kill switches to CDI and
    an earth wire to the CDI. (green)
    I'm assuming you have the multi plugs on the loom and CDI?
    Give it a go one wire at a time.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
    Nov 2008
    wisbech
    Quote Originally Posted by catteeclan View Post
    the wiring loom is all still intact. i removed it so the plugs are still in situ. i will have a go and see how i get on. thanks again.
    Nov 2008
    wisbech
    sorry if i sound a bit dense. on the alternator side of the bike there are two wires coming out. do i need to conect both of these. the multiplugs in the loom only have six wires coming out! also dont want to use the ignition barrell etc.
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Quote Originally Posted by softerz View Post
    Should be 5 wires on the alternator side and 2 on the clutch side?
    What colours you got?
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
    Nov 2008
    wisbech
    you are right there are five. two in a multi plug to the rectifier. three i believe go to the cdi?
    green, blue and white/yellow
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Think this still has the XL wiring in the engine.
    2 in a multipug should be one pink one yellow. Bat charging.
    Is the green light green with a red stripe? Neutral light.
    If it's a green the same as the - bat lead it's earth.
    White/yellow is off to the light swith for headlights.
    Which leaves the blue which should be (or is normally) black with a red stripe to the CDI as power supply. The only wire needed from the alternater side.
    Time to let me know what colours you have going into the CDI.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
    Nov 2008
    wisbech
    i will see if i can get a picture of it on here! it might be a bit easier. all in all i have six wires currently connected to the cdsi. i took the wiring loom off the bike intact.
    does it matter which wire attahces to which plug within the cdi!
  1. R6 Reg Rec wiring
    By Underground in forum Africa Twin
    Last Post: 26-12-08, 10:15 PM
  2. XL500R rear wheel same as XL250R??
    By shaunbaker in forum XL
    Last Post: 18-12-08, 09:16 PM
  3. Wiring diagram
    By MollyandMitch in forum Transalp
    Last Post: 21-09-08, 01:47 PM
  4. CHAPTER 20 - WIRING
    Last Post: 29-07-08, 12:05 PM
  5. which muffler fits a honda XL250R???
    By blablau in forum Other Bikes
    Last Post: 27-10-06, 08:51 PM
