Results 1 to 2 of 2
Thread: regarding starter noise
    north east scotland is offline Junior Member
    Aug 2008
    banff
    i have had this xr650l on a 52 plate for a few months--since ive had it the starter is quite noisy--any ideas--like a grinding noise --any ideas thanks
    rsstom's Avatar
    rsstom is offline Junior Member
    Apr 2008
    Ohio USA
    Re: regarding starter noise
    There's a one-way clutch behind the stator rotor. This is probably where your noise is coming from. The design is called a Sprag clutch in USA, and very common in the motorcycle industry.
    The parts get worn and tend to slip a little, causing a grinding/clunking noise. As they wear more, the starter clutch will spin free, then catch and turn the motor. In the end, the starter clutch will just spin and not engage the motor at all.
    Parts are probably still available from Honda.
  1. TA 600 Starter switch.
    Last Post: 31-10-08, 08:24 PM
  2. Starter motor all the same??
    By Tjokk in forum Dominator / FMX
    Last Post: 18-11-07, 06:21 PM
  3. Starter switch
    Last Post: 01-11-07, 07:49 AM
  4. starter motor removal on a 650
    By daved in forum Transalp
    Last Post: 23-03-07, 06:28 PM
  5. Starter problems...or is it the battery?
    By louis_holtz in forum Africa Twin
    Last Post: 13-04-06, 08:00 PM
