On an 86 model.
In the Clymer manual it says pull up the tip of the tensioner and insert a piece of wire in the hole.
I can't see any hole! I've pulled it up as far as I can, plus pushed in the tensioner down in the chain tunnel but no hole can be seen. The problem being that it will be very difficult to put the cam back on without the tensioner backed off.
The tensioner shows pretty much no wear so I'm wondering if its been replaced and for whatever reason has no hole, a pattern part perhaps?
Any experience/ideas?
Thanks....
Steve
