Re: Bits in Filter Screen (XL250)
Originally Posted by
thedktor
One of the springs has pushed through the case, which appears to be very thin just here.
I’m not worried as the springs don’t normally bear against this part anyway, as they fly outwards on some ramps when the engine is running
It looks like the casting is faulty. I'd check that there are no loose bits of alloy on it and that the spring is not in danger of making a bid for freedom through into the clutch pack where the damage would be catastrophic.
The springs don't fly outward on ramps (like rollers in twist and go transmissions). They are there as part of the cush drive in the back plate and should be a snug fit. If they are loose and rattling about, the basket is shot and should be replaced otherwise it will end up putting metal fragments into the oil which will destroy the top end.
