Results 1 to 5 of 5
Thread: XLR125RW 2000 Reg
    Draxdon is offline Junior Member
    Feb 2009
    Darlington
    XLR125RW 2000 Reg
    Hi
    Newbie to the site.
    Have just picked up the XLR ,No MoT,No Tax and needing some work.
    Siezed front disc brake caliper.
    Anyone got any tips before I embark?
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Re: XLR125RW 2000 Reg
    Push the piston out with all the hydrolics connected, clean and reassamble with new seals and some rubber grease.
    And then put some pics up.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
    Feb 2009
    Darlington
    Will keep you posted cattee clan,thanx
    Bill Badger's Avatar
    Bill Badger is offline Member
    May 2008
    Cannock, Staffordshire
    The piston in the caliper could be seized, but on mine the piston was fine.
    It could be that the pins on which the caliper are allowed to float are seized. If it is, you need to remove the caliper from the bracket and clean up the pins. This may be difficult. as it was on mine. I had to drill a hole in the end of the tube that the pin is supposed to slide in and use a drift to knock out the pin. It may be that only one pin is seized, but whether it is one or both, it mak take an afternoon or so to do it. In the seized state, the caliper cannot centralise about the disc, so one side becomes more efficient than the other, and hence the uneven pad wear.
    Clean up the pins once you have it apart, lubricate with copper grease, and all should be well.
    Feb 2009
    Darlington
    Duly noted.
    Thanx.
  1. 2000 Vara
    By Shepp in forum Varadero
    Last Post: 07-05-08, 07:28 PM
  2. 2000 Xr650r 2 Owners From New
    By minty0_10 in forum For Sale / Wanted
    Last Post: 13-04-08, 09:19 PM
  3. Africa twin 2000 W
    By HUDDERS in forum Africa Twin
    Last Post: 01-05-07, 12:26 PM
  4. 80 mph at 2000 rpm!!!
    By Wanderingmiles in forum Africa Twin
    Last Post: 21-02-07, 12:26 PM
  5. RD 07a (2000) new exhaust (Leo Vince)
    By univet in forum Africa Twin
    Last Post: 23-05-06, 07:12 AM
