Honda Trail Bike Forums
Go Back   Honda Trail Bike Forums > Honda Trail Bikes > XL
Reply
  #1 (permalink)
Old 22-02-09, 05:49 PM
jon jon is offline
Junior Member
xlr 250 sticking brakes
Hi got a problem with my front brake.
I have just fitted new pads,the old ones were down to the metal !
(ive only had bike a few months)
When i out it all back together everything is fine but after a few miles the brakes start sticking on...so much so i cant even turn the front wheel.
Any i deas what could be causing this???
Cheers jon
  #2 (permalink)
Old 22-02-09, 07:28 PM
catteeclan's Avatar
Senior Member
Re: xlr 250 sticking brakes
Most likely is a sticky caliper piston.
__________________
08 TDM900,
96 Dominator,
84 XL600lm,
82 XL500r.
  #3 (permalink)
Old 23-02-09, 11:38 PM
Bill Badger's Avatar
Member
It could be that the pins on which the caliper are allowed to float are seized. If it is, you need to remove the caliper from the bracket and clean up the pins. This may be difficult. as it was on mine. I had to drill a hole in the end of the tube that the pin is supposed to slide in and use a drift to knock out the pin. It may be that only one pin is seized, but whether it is one or both, it may take an afternoon or so to do it. In the seized state, the caliper cannot centralise about the disc, so one side becomes more efficient than the other, and hence the uneven pad wear.
Clean up the pins once you have it apart, lubricate with copper grease, and all should be well.
  #4 (permalink)
Old 26-02-09, 07:35 PM
jon jon is offline
Junior Member
Thanks for the help..have stripped them down ..just waiting for some new seals to be delivered and should hopefuul go back together ok.
Can anyone tell me what do i lubricate the pistons with before i put them back in the calipers?Is brake fluid ok? best?
Cheers jon
  #5 (permalink)
Old 26-02-09, 10:00 PM
catteeclan's Avatar
Senior Member
Make sure you clean out the groves in the caliper where the seals seat.
Rubber grease is best but brake fluid's better than nothing.
__________________
08 TDM900,
96 Dominator,
84 XL600lm,
82 XL500r.
  #6 (permalink)
Old 03-03-09, 10:05 PM
jon jon is offline
Junior Member
Excellent thanks for all the help..all back together and working better than ever before...and just went through mot too...
cheers jon
Reply
Tags
250, brakes, sticking, xlr
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Main Beam Switch Sticking Gaz Africa Twin 6 11-12-08 08:21 AM
Better brakes Simon WS Dominator / FMX 3 20-08-08 09:19 PM
Sticking rear brake howiezowie Transalp 4 18-08-08 09:11 PM
Running on one pot - Sticking choke Pigglet Africa Twin 1 01-04-07 08:46 PM
Sticking Choke? higgo Transalp 10 13-02-07 12:59 PM
