Results 1 to 7 of 7
Thread: Newby with XL500R
    Craig David is offline Junior Member
    Oct 2008
    Cambs
    Newby with XL500R
    Hi people.
    This looks like a great forum.
    I've not long ago bought a 1982 XL500R.
    It's great but is can be slow to settle to tickover and can stick at about 3000 rpm both when in gear or neutral although it generally drops down to about 1300rpm.
    I've spoken to some clever guys on www.xl500.de and they say it's probably wear in the carb, probably the slide I think. They say the first three items on heere should solve the problem: http://www.alttec-classics.de/shop/i...5_vergaser.htm
    Does that sound right? I don't even know what those parts are!
    Here's the bike:
    Krtek's Avatar
    Krtek is offline They say I talk too much.
    Arnhem, the Netherlands
    Re: Newby with XL500R
    I'm not familiair with the carb on the 500s, but coming at the problem from another angle: does it now have two throttle cables or one? Does it originally have two?
    The 600 originally has two, and the second one helps close the throttle. But it tends to get lost over time.
    Lovely looking little bike, by the way, and welcome!
    Apr 2007
    East Anglia-ish
    Very nice bike. And welcome, the parts on the list are for new jets and diaphram and may solve the problem though check your two throttle cables are in place and well lubed also wd40 the springs and gubbins on your carbs and give them a good workout.
    AND A BIG UP TO IBN BATTUTA
    ADVERTISE HERE.
    Absynth eye drops
    see things in a new way
    Oct 2008
    Cambs
    Thanks for the replies.
    There are two throttle cables (an opener and a closer) but they're both operating properly.
    The problem only happens very occasionally but I'd like to get the bike spot on so I'll think about buyng and installing those bits.
    Thanks again.
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Could be also be worth checking for vac leaks as the inlet rubber is a known fault.
    Lovely looking bike that.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
    bigrocketrider is offline Junior Member
    Dec 2010
    Redruth, Cornwall
    Hi Craig
    I "think" I am about to purchase your old XL from a dealership in Cardiff. Before I proceed, is there anything you can tell me - hint, hint. Must be yours as there can't be many around with the arai sticker on the front and carrier on the back. Any info welcome.
    afk40's Avatar
    afk40 is offline Senior Member
    May 2006
    Near Glasgow Scotland
    Hi Guys,, im needing a tail pipe fur ma 84 XL500R,, even a xl500s one would do ifye`s know of any.. thanks,
  1. XL500R rear wheel same as XL250R??
    By shaunbaker in forum XL
    Last Post: 18-12-08, 09:16 PM
  2. Newby questions
    By scorpio stu in forum Mechanical Advice
    Last Post: 17-12-07, 05:09 PM
  3. tips on top end rebuld honda xl500r
    By mattnx650 in forum Dominator / FMX
    Last Post: 25-10-07, 03:41 PM
  4. Stand by for newby XR400 questions
    By Tim Cullis in forum XR
    Last Post: 22-03-07, 08:05 AM
  5. Newby
    Last Post: 10-08-04, 09:52 PM
