Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: XL200R Italian MD06 Frame and Engine
    stretchy's Avatar
    stretchy is offline Snotty lane fan!
    Mar 2009
    Bristol, UK
    There are quite a few of these around, I know I have two. Basically a low compression XR200 with 'leccy start and no kick. The Marzocchi forks are a bit of a problem as they have none standard seals; otherwise a simple fix as most bits in common with other bikes. I like to hear from anyone who has the same machines we maybe of use to each other!
    All the best from Bristol, UK
    Stretchy.
    I luvs me Mud!
    hondaxrnut is offline Senior Member
    Oct 2008
    somerset
    Re: XL200R Italian MD06 Frame and Engine
    see my thread on 'help with paris/dakar.'
    Ed Motorhead is offline Junior Member
    Apr 2009
    Slovakia
    Hi,
    I'm just rebuilding one of MD06 (italians), now I got to the point where I must put electrics on. As I'm trying to make it dirt track bike (like) it's quite mess. I try to put on some pic's as soon as I find out how...
    Ed
    stretchy's Avatar
    Mar 2009
    Bristol, UK
    Nice one Ed, lets see those pictures!
    I now have mine MOT'd so off to get it registered this week.
    Rode it down to the MOT station, first time I've really ridden it and taken it thru' all the gears. Had to adjust the clutch cable up but that was all. Sounds nice and chuggy! Can't wait to get it out in some dirt!
    I'd recommend some Kings tyres as they're nice and cheap, be careful with the profile on the rear as my 'other' XL had a profile so large is fouled the swinging arm even tho' someone had ground it away to clear!
    I can send you decent piccies if you need to see where all the wires go...............
    Stretchy.
    Oct 2008
    somerset
    are you coming to the honda trail bike forums off raod meet next saturday, its not far from you, on the mendips?
    i am going with my cfr and xr special.
    shaun
    stretchy's Avatar
    Mar 2009
    Bristol, UK
    Don't know nuffin' 'bout that?
    Where?
    When?
    Mind you have booked nxt Sat for wkend in Lndn with my family.
    Ah well, do let me know tho'!
    Ta.
    Oct 2008
    somerset
    hi, look under calender, top of page and you will see the dates in the box that comes up.
    there sare about 3 more during the year.
    shaun
    clis is offline Junior Member
    Apr 2009
    cwmyoy s wales
    when i bought mine the engine was rattley so stripped engine,rebored,new wiseco piston,because honda do not do oversized piston.now rebuilt runs fine,but timing too far advanced so pinking and pre ignition on start up(so can anybody tell me if you can alter the timing,as there is no adjustment on cam like uk models
    stretchy's Avatar
    Mar 2009
    Bristol, UK
    You 'DID' fit a new cam chain didn't you?
    Timing is rather easy, OK................
    Remove 2 (allen key) covers from LHS of engine and undo two 8mm bolts from the LHS engine top to reveal cam sprocket.
    With a 14mm deep socket and bar rotate the engine by hand (through the larger of the allen key holes) and look through the smaller of the allen key holes to find 'T' there's also 'F' and 'II'.
    'T' is Top Dead Centre and altho' this position can be found twice (every 180 Degs) you want the one that occurs when Piston is at TDC, may as well take off the valve covers so you can wiggle them to make sure they're both loose (they wont be if your on the wrong part of the stroke).
    OK you've got it all lined up now?
    How's the cam sprocket looking?
    It has a small indent (dot) and this should be pointing straight up towards a small notch.
    It should be bang on.
    Your advance can be checked when the engine is running but is a pain in the ass as whilst you try and shine your timing light in the hole (small allen key one) oil will come flying out because of the crankase pressure. I think it's 'F' at idle (1250rpm?) and max advance 'II' at 4250?, don't quote me....
    Anyway check the 'T' and 'dot' marks line up and also whilst your there rotate the engine with the 14mm socket and check the timing chain tension at various places, I found mine went slack (very) then tight so was repalced (£10).
    You have adjusted the tension of the chain haven't you?
    Let us know how you get on.
    Stretchy.
    p.s. piston wise you can fit a Kawasaki 750 piston in there, I think it give 220cc?
    Apr 2009
    cwmyoy s wales
    cheers strechy,to your first question yes,new cam chain,slider blade,tensioner blade,gaskets etc.cam timing fine its ignition timing is the problem.on british models you can adjust timing by altering back plate on cam but no option italian model.
  1. help with paris dakar xl200r
    By hondaxrnut in forum XL
    Last Post: 04-10-11, 03:55 PM
  2. Rd04 engine into rd03 frame
    By mudbogger in forum Africa Twin
    Last Post: 10-10-08, 02:36 PM
  3. AT Engine and Frame
    By edteamslr in forum For Sale / Wanted
    Last Post: 19-07-08, 09:33 AM
  4. engine /frame mumbers
    By 1965paulh in forum Africa Twin
    Last Post: 26-07-06, 01:17 PM
  5. rd04 engine in a rd07 frame ??
    Last Post: 03-03-06, 05:46 PM
