Results 1 to 6 of 6
Thread: Terrible brakes
    Rigormortis is offline Junior Member
    Mar 2009
    Scotland
    Terrible brakes
    My first post and would you believe it it starts with a question but hey that's what makes Forums so brilliant.
    My son has just bought an XL600V (F Reg) and the front brake is appaling (i.e. useless). Is it because its got a solid cast iron disc? I'm wondering whether there is an upgrade available for this model. Thanks for your help.
    Bill Badger's Avatar
    Bill Badger is offline Member
    May 2008
    Cannock, Staffordshire
    Re: Terrible brakes
    Check that the pads haven't glazed, possibly due to the piston or the caliper itself being stuck and thus causing drag and therefore a lot of heat. Have a good look at the caliper as well. If the lubrication on the slider has dried out it may be siezed and so you could possibly have only operation on one side of the disc. The disc will then flex slightly because it is not being squeezed by the two pads. It could also be a stuck piston or the fact that the parts of the caliper are siezed together. I stripped mine down and freed it up and now it is excellent (XLR200). I'm sure that if I was brave enough I could get the rear wheel off the ground.
    I wouldn't think the cast iron disc would be a problem.
    stuart's Avatar
    Jan 2008
    lancashire
    Re: Terrible brakes
    Go even more basic, give the disc ( and pads ) a scrub with meths, I bought a beta 250 with an unusable front brake, new pads made no difference but after wipping the disc with meths I could stand the bike on i'ts nose with one finger on the brake.
    Aprilia rxv 450 pile of scrap, got a refund
    Honda crf450x
    XS 700 Mercury Twin
    safehouse
    TLD 6/2010 Run For The Sun 15hrs 55 min all in
    TLD 6/2011 Two Towers 14hrs 56 min leisurely bimble
    Re: Terrible brakes
    If it has been standing for a while the brakes may need servicing / Cleaning to get them working properly.
    Mar 2009
    Scotland
    Re: Terrible brakes
    Thank you for your replies - sound like taking the calipers to bits is a must. One other question, Can you get nicer looking discs i.e with holes, rather than the solid one thats in at the moment.
    Bolton, Lancs.
    Re: Terrible brakes
    the front brake is'nt brilliant when it's working properly !
    as said a brake service and new pads is first job, . . . . and a braided hose makes a noticeable difference.
    there are pattern discs available.
  1. brakes
    Last Post: 25-02-09, 09:05 PM
  2. MOT and brakes
    By subby in forum Transalp
    Last Post: 22-11-08, 09:36 AM
  3. Better brakes
    By Simon WS in forum Dominator / FMX
    Last Post: 20-08-08, 10:19 PM
  4. Brakes again
    By markh in forum Africa Twin
    Last Post: 25-02-07, 05:29 PM
  5. BRAKES.....
    Last Post: 22-01-07, 08:53 AM
