Results 1 to 7 of 7
Thread: Xl600lm
    stubbow's Avatar
    stubbow is offline Senior Member
    Mar 2009
    Exeter UK
    Xl600lm
    Picking my xl up on tuesday its been sat for a while not sure how long seller said anything up to 12years but it doesn't look like its been stood that long to me
    Anything i should check before trying to start it
    going to put new battery, clean carb, new plug and flush tank and put in fresh fuel and oil.
    Plan is to get running before stripping it for a full rebuild at least then i know what i need to do.
    Any common faults i need ti know about?
    Danny
    Re: Xl600lm
    Use cheap oil for the first couple of starts as it may need to be flushed through.
    Apr 2007
    East Anglia-ish
    Re: Xl600lm
    HI take a valve cap off and pour a cup full of oil into the head, and if your fitting a new plug put a squirt of wd40 into the hole to break any dry sieze before the piston moves.
    If it hasn't moved for a few years the tyers and tubes will be goosed and cracked so be carefull before ripping off down the lane,same with brake pads-lines-fluid.Other than that give it a twist and enjoy it......
    AND A BIG UP TO IBN BATTUTA
    ADVERTISE HERE.
    Absynth eye drops
    see things in a new way
    stubbow's Avatar
    Mar 2009
    Exeter UK
    Re: Xl600lm
    Thanks for the advice what grade of oil do they use and what plug do you recommend, still not 100% which model i have yet
    Whats the difference between LM and RGB(or something like that)
    I wish i had arranged to pick it up sooner im getting itchy fingers
    Danny
    Apr 2007
    East Anglia-ish
    Re: Xl600lm
    Hi i personally use castrol 10w40 both in the twin and the xl.semi synth gps does it for me as to the letters after xl600 it denotes the model change/run/engine colour/year and so on though they lived from 83 to 86 ish before they lost the plot alltogether. if you go to wemoto and type in xl600
    http://shop.wemoto.com/index.dyn and have a look around you will get the gist of it soon enough......mel
    ADVERTISE HERE.
    Absynth eye drops
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    Re: Xl600lm
    and Danny the oil pump pumps oil around the engine not into the manifold on these things. you have camshafts and valves to deal with
    and it is NOT meant smoke out of the exhaust
    merv
    stubbow's Avatar
    Mar 2009
    Exeter UK
    Re: Xl600lm
    Camshafts Valves never heard of such things why would you need them
    I was hoping to run it on Castrol R for that authentic 80's smell
  1. Xl600lm rebuild
    By meljordan in forum XL
    Last Post: 16-04-10, 08:28 PM
  2. XL600LM parts wanted
    By rsstom in forum For Sale / Wanted
    Last Post: 15-04-08, 02:07 AM
